Removing Intermediate Exhaust Pipe
Old 04-19-2024, 07:39 PM
Mac Allan's Avatar
Default Removing Intermediate Exhaust Pipe
I still need to replace the U-joint at the transmission, but when I last tried to remove the intermediate exhaust pipe I couldn't get it to budge. I had soaked the joints with PB Blaster overnight and was confused because I didn't recall having any trouble before when I replaced the transmission mount. I decided to give it another go this weekend and put the beast on the QuickJack so I could get under it and spray some more penetrating fluid to work overnight. When I opened the cabinet to grab the spray can something caught my eye, and I had one of those 'aha!' moments followed by 'oh no'. This is what caught my eye, a tube of this:
https://versachem.com/product/exhaus...-crack-sealer/
When I did the trans mount, I must have used that on the joints when I reassembled the exhaust, which would explain why the penetrating fluid wasn't working and why I could not get the joints apart.
Any suggestions on how to break the bond?
Old 04-19-2024, 09:12 PM
Jagboi64's Avatar
Received 3,070 Likes on 2,038 Posts
I suspect an oxy-acetlyene torch and get the parts red hot is probably the only way.
The following 2 users liked this post by Jagboi64:
JJS- Florida (04-20-2024), Mac Allan (04-20-2024)
Old 04-20-2024, 09:33 AM
MooseOHJ's Avatar
I second this. The SDS sheet lists Kaolin Clay as the main ingredient of what he used. Get it hot and brittle and some soft hammer taps might break it free.
Old 04-20-2024, 12:03 PM
nickr76's Avatar
3 bolts at down pipe, 3 bolts at rear, always drops right down for me. Where is it getting stuck?
Old 04-20-2024, 12:10 PM
Mac Allan's Avatar
The US spec 4 catalyst system doesn't use the 3 bolt olive in the front, it's a slip joint/clamp connection:
https://parts.jaguarlandroverclassic...tml?code=21914
Old 04-20-2024, 08:02 PM
Mac Allan's Avatar
Success!
I don't have access to an oxy-acetlyene torch, but a MAP Pro torch was hot enough to get it cherry red. Took several cycles but each joint finally gave up.
Thanks for the tip, much appreciated. I will NOT use that product on reassembly.
JJS- Florida (04-21-2024)
Old 04-25-2024, 09:23 PM
Mac Allan's Avatar
On reassembly I "sealed" the joints with high temp anti-seize. I guess we're never too old to learn.
Old 04-25-2024, 11:29 PM
Jagboi64's Avatar
Band clamps instead of the U bolt ones make a difference too. If you get an Easy Seal they will stretch over the joint and seal it very well.
Mac Allan (04-26-2024)
muttony
03-28-2023 09:01 AM
muttony
01-03-2023 07:23 PM
Lady Penelope
05-26-2021 09:32 PM
novemberjazz
12-27-2019 01:07 PM
JagYour
08-28-2011 12:37 AM
Quick Reply: Removing Intermediate Exhaust Pipe
