Rebuilding the fuel lines
Old 06-04-2013, 08:59 AM
Calhale's Avatar
Default Rebuilding the fuel lines
I'm finally returning to the XJ6 (1985) that has languished in the bodyshop (quality, price and speed: pick 2) since Nov. The tanks were dropped and new ones purchased in while it was in there (so the Por15 can be put every-which-where it should go).
Unfortunately, I don't have a terribly good manual for verifying the fuel plumbing is rightly restored. When I purchased the ol' girl, the DPO had plumbed the fuel pump directly into the RH tank, and so I need to verity he didn't screw around with anything else and I need to restore her to the original lines.
Does anyone have a favored collection of images/diagrams, etc. that they'd recommend I start with?
I'm starting with:
An old Haynes guide to the Series 1,2 and 3 (not my fav. resource).
What I can scrounge from A6: Fuel injection and the Jaguar XJ6 4.2 Series 3 / AJ6 Engineering
I'm afraid the search on this forum is rather target-rich for fuel line discussions.
Old 06-04-2013, 09:44 AM
Sarc's Avatar
I've been using the parts manual mentioned in this thread...... https://www.jaguarforums.com/forum/x...iagrams-95362/
Extremely useful. There are 4 diagrams of the various parts in the trunk required for a "proper" fuel system.
I have an original unmolested '84 car which I believe to be completely correct in the fuel tank department.... if you need pictures of the trunk area, let me know and I'll snap some for you
Old 06-04-2013, 10:05 AM
Calhale's Avatar
Thanks.
Any pictures of the fuel pump, fuel switch, and how the two tanks plumb into it would be a great start for me.
Also: any experience in priming the circuits? I planned to simply put a bucket beneath the return to each tank and run the pump until fuel came out.
Old 06-04-2013, 10:38 AM
john_cook12's Avatar
here are some images which may help
all images below depict a 4.2L fuel injection system
Attached Thumbnails Rebuilding the fuel lines-1.jpg   Rebuilding the fuel lines-2.jpg   Rebuilding the fuel lines-3.jpg   Rebuilding the fuel lines-4.jpg   Rebuilding the fuel lines-5.jpg
FastKat (06-05-2013)
Old 06-04-2013, 12:41 PM
Calhale's Avatar
Excellent, I pulled those very ones from the link provided. Does anyone have a shot of the tank switch/fuel pump hookup?
Old 06-04-2013, 05:08 PM
Fraser Mitchell's Avatar
Received 2,425 Likes on 1,937 Posts
The diagrams supplied here omit the pipes from the two tanks to the fuel supply changeover valve. Unforunately, I don't have a diagram, but it will be in the same publication as the others have come from.
Having pulled everything apart in this area around 1992 prior to a major panel replacement job, I can tell you that on each side there is a fairly short 3/8 OR 1/2" diameter pipe. (About 4-5" long) coupled to the lower inner side of the tank, crossing the bottom, (open side) of the exhaust space, then into the lower boot (trunk) side via a hole about 1" in diameter with a protecting grommet. Having now got a pipe each side from each tank protruding into the lower trunk space, (behind where the spare wheel goes, and protected by a cover), the fuel change-over valve is mounted nearby. The two pipes are coupled to the valve using the usual fuel hoses, and then the changeover valve is coupled to the pump which is mounted on an anti-noise and vibration mounting. The exit pipe from the pump is then attached to the fuel supply pipe.
So that's the fuel supply arrangement, the fuel return pipes never get into the trunk space, they get to the tanks at their front via the inner wheel arches where the other changeover valves are found (as per diagram)
Old 06-05-2013, 11:33 PM
FastKat's Avatar
Thanks a lot for posting those pictures. I am thinking about eliminating that 3-way check valve, and those are just the pictures I needed to see.
Old 06-06-2013, 07:40 AM
FastKat,
Sure thing. I had success removing that three-way valve you describe in my 2nd car, a green 84 XJ6, when the PO advised not using the right tank due to some corrosion (surprise) in order to prevent myself (or someone else) accidentally pulling from the wrong tank or letting a loose sealing valve leak a little dormant water from the bad tank to the good tank/fuel lines.
Edit:
Don't know why I didn't include this one in the original post but here is a diagram showing what connects to the changeover switch, from where, and where it is going. Unless I'm much mistaken, this is the diagram to which Fraser Mitchell is referring above. Hope it helps.
This part ^ is part no. CAC8000, depicted in the bottom left corner of this one
V
Attached Thumbnails Rebuilding the fuel lines-switchover.jpg   Rebuilding the fuel lines-switchover2.jpg
Old 06-06-2013, 09:17 AM
Calhale's Avatar
As I recall: the two lines going to the switchover valve in the trunk are 1/2 inch, and 3/8 from the pump on, right?
Old 06-06-2013, 09:58 AM
It is definitely 1/2" going to the switch and I'm pretty sure you're right about the 3/8" from pump forward.
Old 06-06-2013, 11:15 AM
FastKat's Avatar
Sorry for the confusion guys - when I said "3-way check valve" I did not mean the fuel tank selector... I meant the CAC2028 check valve that burps air back to the return system and also serves as a one-way check valve to maintain fuel system pressure after shutdown. I really don't know what to call that thing - I think it's a relatively trouble-free part, so there's not much documentation on it.
Whatever it's called, I think I am going to bypass it and run 3/8" hose from my pump directly to my new 3/8" fuel filter. I have a supercharger that demands high flow at a very high pressure, and a little extra flow capacity will help the fuel pump deliver.
BTW, on my 1985 XJ6, most of the pressure side connections (from the outlet of the fuel pump through the fuel filter) are all 5/16 fittings, 5/16 steel line, and 5/16 hose. The fuel pump and the fuel filter have 5/16 hose barbs. However, the steel fuel line that runs from the spare tire well to the engine seems to be 3/8" when measured with a caliper. I think the 5/16" hose is simply forced over the 3/8" steel line that protrudes into the spare tire well. I dealt with this about a year ago when I replaced all the dried-up hose with new 5/16" high-pressure fuel hose.
Old 11-23-2013, 10:45 AM
caddys45's Avatar
Default 85 xj6 fuel supply and return piping
I'm experiencing a fuel leak on the right side of my 85 xj6. Don't know the source yet but it appears to be a tank overflow. I suspect that the right side return valve may no be closing or functioning properly. The return piping to the tanks is mostly hidden making my inspection difficult. I'm trying to avoid dropping the tank(s). What happens if the tank change over valve is eliminated with a tee and both return valves are eliminated with tubing? Won't both tanks then act as a single tank and seek a common level? In other words the fuel pump will be always be drawing from both tanks and returning to both. A less complicated configuration and the selector switch isn't necessary. I don't see any obvious problems with this. Any thoughts or comments?
Lee
silkcat
04-15-2023 04:58 PM
dsnyder586
04-04-2019 02:38 PM
lovemyjag78
09-14-2015 07:42 PM
1964Daimler
09-09-2015 04:50 PM
Jay48
09-07-2015 09:30 PM
Quick Reply: Rebuilding the fuel lines
