Fuel tank pressure sensor
Old 04-11-2013, 10:58 AM
coastaljag98's Avatar
Default Fuel tank pressure sensor
I'm getting a P0453 code that keeps setting and won't erase. I've read that this is evaporative emissions sensor input too high. I'm assuming this means that the sensor is bad. Since I don't want to remove the damn tank AGAIN after JUST replacing fuel pump about a month ago, please tell me that this sensor is NOT inside the tank and can be changed without pulling the tank???
Old 04-11-2013, 09:31 PM
Bump
Old 04-12-2013, 08:06 AM
jimlombardi's Avatar
It appears that the Fuel Tank needs to be removed to replace the Fuel Tank Pressure Sensor.
Here is the JPEG file I created from the JTIS software's on this sensor removal/install (click on the image when the webpage opens to get a sharper view):
https://www.dropbox.com/s/kqrhol3vne...%20R%26R.jpg?m
I also included a number of photos I found on the internet showing the sensor part number and where it is located.
The only price I could find for this part was on gaudin jaguar parts.com - List price $141 discount down to $114.
Found a used one on Ebay for $74.
Jim Lombardi
Old 04-16-2013, 06:04 PM
Thanks I believe thst the harness for the sensor is gone. Lol. I will have to buy a damn sensor for the harness lol
Old 04-18-2013, 10:36 AM
jaguar jon02's Avatar
got a 98 vdp . if you have a harman karman radio with the rear speaker. you can remove it and the sensor is 2 in to the left. little black thing that looks like it just pops out and pushes back in.( just looks like it ) might try later and see
Old 04-18-2013, 10:44 AM
Default sensor
Jim Lombardi
i looked at mine 1998 vdp and the sensor is on the other side of the white plug behind the vent tube
Old 04-18-2013, 03:28 PM
The pressure sensor is on the Evaporative Loss Flange Assembly (the assembly is mounted on top of the gas tank).
Here is what the JTIS says:
The evaporative-loss flange assembly is mounted centrally on top of the tank.
The flange assembly consists of a removeable steel cap which mounts the evaporative emissions system vapor outlet valves and, if applicable, a pressure sensor.
The external electrical supply to the fuel pump(s) is also made via a connector on the flange.
Jim Lombardi
Old 04-18-2013, 08:13 PM
Mine is missing a wiring harness lol. Just figured it out. Got one coming so all should be well soon.
Old 04-20-2013, 01:34 AM
Last Jaguar's Avatar
so the issue was absence of wiring? since i am not a mechanic with low knowledge in repairing cars, i thought that it might be faulty ventilation system, or valve or whatever that keeps the pressure in tank in normal limits. as in boiling cattle that has pressure valve that opens when pressure is too high. if it doesn't work than pressure rises and it could be the reason why that sensor was showing constant high pressure i know, i need to read more
Old 04-20-2013, 08:17 PM
Yes when we replaced the fuel pump we misplaced the wirin for that sensor and we never noticed it. We had a bad maf sensor and thought that was giving us all the codes. Then we shine a light at the tank and see its gone lol. A forum member is sending me a harness he had so I should be good to go!
Old 10-22-2014, 01:00 AM
Rob_hook's Avatar
The fuel tank definitely doesn't have to come out and you don't need to remove the rear speaker or package shelf. Replace this by removing the carpeting from the front wall of the trunk. Replacing this sensor this way is a 5 minute job and that's if you stop for a smoke.
toronadomike
08-07-2022 03:41 PM
dsnyder586
04-04-2019 02:38 PM
fingers
09-08-2015 03:54 PM
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
Quick Reply: Fuel tank pressure sensor
