How to remove side mirror cover
Old 03-29-2013, 05:39 AM
Vector's Avatar
Default How to remove side mirror cover
I am thinking of wrapping my side mirrors with carbon fiber film and wanted to know if the side cover panel just pops off some clips at the mirror base at the red line below or is it held in place by some other fasteners under the mirror itself?
Vector
Old 03-29-2013, 06:15 AM
jimbov8's Avatar
Hi Vector,
Please find attached the removal procedure for the mirror covers.
You will have to remove the glass first in order to access the inside of the cover.
Hope this helps.
The following 2 users liked this post by jimbov8:
fredd60 (03-30-2013), Vector (03-29-2013)
Old 03-29-2013, 07:28 AM
Vector's Avatar
So the glass just pushes out towards the outside to remove? I had seen this procedure written up before but it is not really clear how the glass releases from the backing.
Vector
Old 03-29-2013, 08:57 AM
jimbov8's Avatar
Hi Vector,
The glass clips into the motor assembly.
By holding the inward side of the glass whilst gently pulling at the outward side, you are, in effect, levering the glass away from yhe motor assembly.
Hope this helps.
Vector (03-29-2013)
Old 03-29-2013, 12:46 PM
jimlombardi's Avatar
Received 1,620 Likes on 874 Posts
Here is a PDF file on rear view mirror - instructions & diagrams extracted from JTIS shop repair software:
XJ X308 Exterior Mirror Instructions.pdf
Jim Lombardi
The following 4 users liked this post by jimlombardi:
chris-jag (12-14-2019), fredd60 (03-30-2013), Jackson Thompson (05-31-2015), Vector (03-29-2013)
Old 05-31-2015, 09:47 AM
Jackson Thompson's Avatar
This helped save me $. The mirror in my color was selling on ebay for $50 more than one in another color. But having a can of touch up paint and one of clear coat, it is the right color now. I got the cover off and back on no problem with these instructions. It was surprising how quick and easy the glass popped off when you know the trick.
Thank You
Old 03-20-2017, 01:29 AM
Jetset767it's Avatar
Default Door Mirror Cover replacement
How do I download the instructions, I'm only getting an Advert
I have a 2013 XJ told my friend my car was too big to get through his village way up in the mountains ended up scratching my door mirror cover my luck changed when someone on eBay had changed their cover for chrome ones .
Vector
Old 03-20-2017, 03:56 AM
GGG is offline
Received 16,823 Likes on 12,178 Posts
I have a 2013 XJ .......
Welcome to the forum Jetset767it,
Two issues here:
1. this is the X308 model forum for the 1997-2003 XJ8
2. until you have minimum number of Posts/time on forum, you can't download
Time isn't a problem as I see you've been a member since April 2014.
Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old 11-28-2021, 06:45 PM
EscapedApe's Avatar
Attachment 37791
Jim Lombardi
Hmm, I'm worried I'm missing something here...
I have a replacement wing-mirror not yet attached to my car. I'm attempting to remove the mirror glass so I can then remove the backing cover to repaint it (I may be fussy, but don't think the gold colour will go well with my black XJ).
I can tip the mirror outwards, as per the diagram, and push the edge away from the car and pull it slightly away from the unit but I'm paranoid the mirror will break as it doesn't seem to be releasing
Any sagely advice?
Troy.
Old 11-28-2021, 11:10 PM
EscapedApe's Avatar
Okay, so, I figured this out...a bit of patience, listening for the click, once you get it, it's easy
worrasf
04-21-2021 05:30 AM
Fenton
01-17-2020 12:10 AM
Sparkplug
06-17-2019 11:59 AM
shift
01-01-2015 05:38 PM
poupinz
General Tech Help
10-12-2014 11:29 AM
Quick Reply: How to remove side mirror cover
