Flat Battery - Boot Key Lock Seized
Old 03-06-2013, 04:41 AM
Chas2008's Avatar
Default Flat Battery - Boot Key Lock Seized
The battery in my X300 Sovereign is flat and the boot key lock is seized up.
If I connect a charged battery positive feed to one of the engine bay fuse boxes and a negative to an earthing post, will this give me power to unlock the boot using the boot release button?
I could then access and charge the battery.
Chas
Old 03-06-2013, 05:23 AM
jimbov8's Avatar
Hi Chas,
Yes it would. May I also suggest that once the battery has been recharged, you spray the bootlock with WD40 or something similar, leave for 24 hours and gently work the key in the lock.
This will help to avoid a similar situation in the future.
Hope this helps,
Chas2008 (03-06-2013)
Old 03-06-2013, 05:40 AM
Ziggy's Avatar
Just to check; you're not trying to use the green key in the boot lock, are you?
Old 03-06-2013, 05:59 AM
steveinfrance's Avatar
That was very polite, Jim.
Easily forgotten but, once again, message to all our readers - even if it's raining go out now and check your boot lock works.
I put some 3in1 on the key but if I knew what I was doing I'd use proper lock lubricant.
Lock lubricant in the Limousin ! You can buy cart axle grease and rings for pig's noses in the ironmongers but lock lubricant ??
Old 03-06-2013, 06:31 AM
Chas2008's Avatar
Thanks Jim, it worked a treat, boot open and battery removed and charging. boot striker removed so I don't lock myself out before the battery goes back in,and at the first opportunity will check/lubricate the key lock and internals to make sure it works in future.
No Ziggy I was not using my valet key.
Chas
Old 03-06-2013, 07:07 AM
Ziggy's Avatar
Chas
Just checking! Glad you got it sorted
I don't know about in France, but here you can get lock lubricant from pretty much anyone that'll cut keys - Timpsons etc.
Old 03-06-2013, 07:49 AM
Our keys look like this
Attached Thumbnails Flat Battery - Boot Key Lock Seized-il_fullxfull.367378506_gggs.jpg
Old 03-06-2013, 08:58 AM
jimbov8's Avatar
Which one is the valet key?
Old 03-06-2013, 09:08 AM
Ziggy's Avatar
Old 03-06-2013, 05:20 PM
Chas2008's Avatar
Old 03-06-2013, 08:05 PM
plums's Avatar
Well then you don't need lock lubricant. The tumblers are so big the lock lubricant wouldn't stay. You pack them with the cart axle grease from the ironmonger.
See how well your local retailers understand their market?
Old 03-07-2013, 11:23 AM
AL NZ's Avatar
those keys aren't X300, they're Swallow Sidecars ones
99xk8guy
09-21-2019 07:34 PM
dsnyder586
04-04-2019 02:38 PM
XJsc-guy
11-23-2015 01:56 PM
speacock
09-10-2015 12:14 AM
philwarner
09-02-2015 11:45 AM
Quick Reply: Flat Battery - Boot Key Lock Seized
