Im locked out of my X-Type!!!
Old 01-19-2007, 04:23 PM
Default RE: Im locked out of my X-Type!!!
[sm=feedback.gif] Hey bigmark, just trying to help you out a little...
Old 01-19-2007, 10:36 PM
BuckMR2's Avatar
I was locked out of mine last year when I locked my keys in the boot.(After opening boot with fob with rest of car locked then closing bootlid with keys in boot[&o]).There are two ways to enter your car without braking the windows etc.If your car doesnt have a CD changer there is a grommet under the cd changer where you can get a metal rod through and short a wire causing the tailgate/doors to open.If you do have the CD changer in the boot you cant use this method as it gets in the way.The other method is to mask around the drivers door/wing so as not to damage the paint.Get the metal rod and poke about between the slight gap between the door and the wing (about 3/4 of the way down the gap where the wiring harness is that goes from the doors to the bottom of the A frame near the door hinge if I remember) which was the method used to unlock my doors.It might take a bit of trial and error to short the correct wire.On mine as the alarm system was on when I locked my keys in the boot it was stillwhen the doors were unlocked using this method.Keys were retrieved from the boot by removing the rear seats once inside the car (wish I'd had folding rear seats!).No problems with door locks before orafter this method was used and now proud owner ofa spare key fob
Old 01-19-2007, 10:59 PM
racerx82's Avatar
i too was once locked out...and the owner wasn't home.
Old 01-20-2007, 02:24 PM
aquill1's Avatar
That stinks racer!!!
Old 01-20-2007, 07:41 PM
racerx82's Avatar
Yeah, but i got in and it's all good now
BadKat174
05-26-2023 12:29 AM
XJsc-guy
11-23-2015 01:56 PM
ssshield
09-24-2015 08:29 PM
Dickie_L_J_O
09-13-2015 07:44 AM
tonyforman
09-10-2015 07:23 PM
Quick Reply: Im locked out of my X-Type!!!
