seat modules for a 2001 XK8
Old 01-24-2013, 05:52 PM
jamesneely's Avatar
Default seat modules for a 2001 XK8
I have a problem with my seat modules and can get LJE2160AG modules. The modules in mine are LJE2160AB. Will these work? If not, how come?
Thanks for any info
Old 01-24-2013, 06:10 PM
GGG is online now
Received 16,799 Likes on 12,168 Posts
When I was after a replacement I was told a later suffix can be used BUT it needs to be from a vehicle with the same options or it would need reprogramming. Based on this, the AG module could replace the AB module.
The advice worked for me but wait for other opinions. I may have just been lucky!
Old 01-24-2013, 06:13 PM
test point's Avatar
The driver side module must communicate across the CANetwork and not only the part number but the extension (/xxx ) is required. The passenger side does not communicate and I suspect that the range of functional part numbers is much broader.
I need a passenger one also but with two other cars under restoration I am going to let you confirm my thoughts before exploring further.
toronadomike
08-07-2022 03:41 PM
Clamdigger
09-12-2015 03:43 PM
skadmiri1
09-09-2015 11:27 AM
Kmw
09-08-2015 04:52 PM
joey g
US Northeast
09-07-2015 06:28 PM
Quick Reply: seat modules for a 2001 XK8
