1984 xj6
1984 xj6
Howdy all! I'm looking at a 1984 XJ6 today, ad came from Craigslist. I have been surfing the posts here for a couple of days and they've been really helpful, but I have a couple of questions:
1) Owner said the car was purchased originally in Mexico, is that relevant?
2) Owner said she couldn't start the car these past couple of days when the temp. hit 5 degrees heck at night it was in the neg. numbers. The car has been sitting for 2 months without being driven, before that it was a daily driver so is there anything in particular I need to look for?
3) From pictures the car looks perfect no rust, dings or other imperfections. She is asking $3k for it...is that reasonable? I was thinking that if she couldn't get it started when I go over today to try and talk her to selling it for $2k.
For rust you should check around the lower corners of both front and rear screens. Few other places would be around the lower trailing arms supports, the under rear valance and the lower rear part of front fenders. If these don’t line up perfectly with the rest of the body and instead stand proud, there is rust forming behind them forcing them out of alignment.
Remember, mechanical work is so much cheaper to do than either body or interior work.
Check the Engine Oil, does it have coolant mixed in? (dipstick is on the driver's side, the one with a Round Ring)
Check the Coolant Cap, does it have oil mixed in ? (there is a brown plastic tank with a radiator cap on the driver's side, remove the cap and look inside if engine is cold).
Bring a large Beach towel, lay on the ground, look underneath everywhere, anything leaking massively? exhaust system rusted?
use your common sense, if it doesn't look right, it never is. $3,000. is about the cost of an entire interior. Look at the interior Headliner, is it good?
otherwise, if it is mint, $3,000. is not bad. Maybe $2,500.
Congratulations.
Thanks guys, the car was dirty and needed a good wash so I wanted to wait until that was done before I took some pics. Picking up the car on Friday and it goes straight to a custom shop for a detailing to fix some minor annoyances. Here was the Craigslist ad that has some pics 1984 Jaguar XJ6
Received 10,741 Likes
Hey, it looks great.
You may not realize it but you have a non-USA model....probably a Jaguar "Soveriegn". Must be grey market import.
The smaller bumpers are the first clue. The there's the clock instead of a trip computer, the XJ6-type seats together with the VanDenPlas type door panels, and then the Pepperpot wheels. It might well have the higher compression engine as well.
Looks like you "done good" :-)
DD
No Jose the Vanden Plas had different seats. However this has already had some upgrades added. The reading lights in the rear seat area for one. I would definately add a third brake light and would get rid of those Black sunvisors and replace them with doe skin coloured ones. There is also a few other upgrades that could be done but other than that, looks like a really nice car.
I don't think it could be a Sovereign unless it has a Vin number higher than 370502. My money is on it being a non USA XJ6 that has had some parts added.
The owner said that it was purchased in Mexico but the rear emblem has Sovereign badge..well part of the badge as it's mostly gone. It's also a 4.2L if that means anything. It's running now and I drove it a few miles yesterday, ran great and the engine bay is really really clean! And I really love the "pepperpot" rims. I forgot to write down the VIN but I pick it up tomorrow, I'll get it then.
Some of the minor annoyances I'm getting fixed tomorrow:
1) Touch up paint, lots of tiny scratches that you can't see until you're close. No dents or dings and 0 rust.
2) Driver seat needs minor repair, has two slight rips that I want fixed before the rips get bigger.
3) Sun visors, don't match the interior. Going to replace with tan ones.
4) Windows slow to respond in opening and closing, think there's a disconnect with some wires because the windows do go up and down but you have to push the buttons multiple times.
5) Door plastic seals are getting old and saggy, going to replace them.
6) Thinking about removing the side trim, think it would look better without it as the rubber in the chrome shrank over the years and don't run the full length of the chrome trim. Either remove it or replace the rubber part.
Oh, do any of you know where I can buy the Sovereign badge for the rear? Most of it broke off and all that's left is "eign" which is annoying.
Thankfully most of my fixes are minor and wont cost much. Once I have a few thousand miles put on this car I'll start making it look nicer with some aftermarket stuff.
