Valve Cover Gasket Replacement - Need How To
Old 09-28-2012, 04:35 PM
OldMike's Avatar
Default Valve Cover Gasket Replacement - Need How To
I would like to replace the valve cover gaskets, etc. and need two things: (1) where to get the "kit" or parts, and (2) a how-to on the procedure.
I thought there was a thread about this but can't seem to find it. I remember reading the thread because it stuck with me that people were saying that the LS1 parts are less expensive but the same as the Jag parts. I did find a thread with a mediafire link, but the link doesn't work - I think it was supposed to be a step-by-step how-to.
My mechanic told me today that it would cost me $1,180 plus tax for him to do it! YIKES!!!! That includes the gasket, plug seals, and the 14 other parts (what are they called?). Seems a bit (a lot) high to me! He said it would take at least 8 hours, but I would think it could be done in a lot less time than that. I told him no!
So, any help would be appreciated. I have a little experience with working on engines, but I'm no expert by a long shot. I can handle a wrench and follow directions, though.
Thanks for any help or advice.
Old 09-28-2012, 06:53 PM
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
It is the 2001 Lincoln LS1 gasket set, I think. If you have the 4.0L engine that should work. Here is one of the secondary tensioner procedures:
https://www.jaguarforums.com/forum/x...ics-how-52653/
If you just need to replace gaskets that is a rather easy job, and should take a couple of hours max. It sounds like your mechanic was quoting you a secondary tensioner replacement at the very least.
RJ_____________
97 XK8 86K mi
Old 09-28-2012, 07:18 PM
test point's Avatar
That is the 2000, or '01 Lincoln LS gasket set. FelPro has the complete gasket set for less than $40 at your local auto parts store. I would make the assumption the the '14 parts' are the seals around the bolts which are included in the above mentioned set.
This is a one + hour job with a $10 set of 1/4" sockets. Biggest issue I had was removing the oil dip stick tube which is really not that hard. Need further guidance check here:
https://www.jaguarforums.com/forum/j...17/#post316489
Your '03 car does not need the tensioners replaced.
I would ask your mechanic to tell you that your are stupid to your face before leaving your car with him.
JimC64 (10-13-2012)
Old 09-28-2012, 07:46 PM
OldMike's Avatar
No kidding! LOL
Thanks for all the great info.
Old 09-28-2012, 09:37 PM
coastaljag98's Avatar
if you can't get them from there, get them on ebay. It seriously is easy! Replace your tensioners at the same time if you haven't since you're already in there. My dip stick wasn't even connected and the valve cover came off without any problems.
Old 09-29-2012, 05:32 AM
Sean B's Avatar
careful not to loose any bolts, the cam cover bolts usually stay in the cover, held by the rubber o rings. I use a magnetic tray to hold the coil bolts.
You'll also need to Loctite Ultra Grey gasket sealant to put a small blob at the timing cover junction.
Also use a torque wrench to tighten the cam cover bolts back down to 9Nm, over tightening can crack the covers (usually once the engine has warmed up and the main reason they leak in the first place).
Good luck, it's a nice easy job
Old 09-29-2012, 06:33 AM
OldMike's Avatar
Thanks again for all the great advice. My first step is to find the gasket kit.
This is my only car, so once I start taking it apart, I have to finish the job -- therefore I need everything before I get dirty!
I found this at partsgeek.com using "2003 Jaguar XJ8" for the search - http://www.partsgeek.com/catalog/200...asket_set.html
And this at Advance Auto using "2000 Lincoln LS 3.9" for the search - http://shop.advanceautoparts.com/web...pro_99992753-p
I know that sometimes the photos/diagrams/drawings aren't exactly what you get, but it concerns me a little that these two kits have some differences. Can anyone help me with the selection?
Old 09-29-2012, 06:58 AM
Sean B's Avatar
partsgeek set look to be right, i.e. Jaguar 2003.
Old 09-29-2012, 12:53 PM
test point's Avatar
. . . as does the Advance AP FelPro set.
I am surprised at the price increase. They were less than $40 a year ago but you do get 20% off and free delivery to the store.
Don't own any Advance stock but sure do spend a lot of money there.
Old 10-13-2012, 07:05 AM
OldMike's Avatar
Question -- how do I know that I'm getting the right stuff in the gasket set? For example, the JTIS shows spark plug seals that look like O-o-O but the FelPro and partsgeek sets show simple, round seals? Are there possibly two different engines and I need to find the set for my particular engine?
As I said before, I'm concerned because this is my only car right now and I can't afford to tear it apart and then find out I have the wrong parts.
Thanks.
Old 10-13-2012, 07:22 AM
RJ237's Avatar
The connected center gaskets were used in the AJ26 engines, the earliest version. You can, I believe, use the fel pro set available at most auto parts stores.
RJ____________
97XK8 86K mi
Old 10-13-2012, 06:39 PM
jimlombardi's Avatar
Hi
I purchased the Fel-Pro valve cover set VS50724R (Ford, Lincoln 3.9L Engine DOHC 2000-2006) for our 2001 XJ8 from Rock Auto.com totaled $43.89 (includes $8.44 shipping).
Advance Auto Parts price is $64.00, but if you purchase it online, then apply promo code A123 (discount of $20.00) brings it down to $44.00 and use the pickup option for your local store (no shipping costs & you can go pick it up within an hour or more).
Update: Advance Auto Parts price now is $68.00 and promo code A123 no longer usable - but new one - TRT30 is (30% Off Your Order. $50 Maximum Savings Online only).
Jim Lombardi
JimC64 (10-13-2012)
Old 10-14-2012, 07:49 PM
theusualsuspect's Avatar
HEY OLDMIKE...
CHECK THIS OUT... Fel-Pro VS50724R Valve Cover Gasket Set | eBay
UNDER 42 BUCKS SHIPPED TO YOU IN 3 DAYS...I JUST USED THESE ON MY JAG..2002 VDP AND WORKED PERFECTLY...TOOK AWAY A CYLINDER MISFIRE ON MY JAG. WE DID USE SOME SORT OF GASKET SEALANT..CANT REMEMBER THE NAME BC SOME OF THE GASKETS LIKE PLUGGED IN ALMOST WHILE SOME DID NOT SEEM TO STICK THAT WELL..THE BIGGER ONES THAT ARE LIKE 1 LARGE PIECE...ONCE WE DID THAT IT STUCK PERFECTLY. MY DAD WOULD KNOW THE NAME OF THE STUFF IF U NEED IT.
Old 11-22-2012, 06:50 AM
The Fel-Pro VS 50724 R Valve Cover Set includes:
1) Valve cover gasket - Left
1) Valve cover gasket - Right
28) Valve cover grommets
1) Oil tube O ring
4) Valve cover rubber seals
8) Spark Plug tube seals
Jim Lombardi
Old 11-22-2012, 07:47 AM
Where are we at with this OldMike?
Are you good to go, do you have enough info etc?
Please update the thread when you can
Old 11-22-2012, 10:36 AM
OldMike's Avatar
I'm on vacation, won't be home for several more weeks, will get back to this project at that time.
Old 03-08-2014, 05:54 PM
OldMike's Avatar
I finally got around to doing this project. Took my time, went to the parts store twice because they gave me the wrong gasket set the first time. Had to remove the cover after getting it all together and properly torqued because I forgot to use the two dabs of gasket sealer! Put it back together and it works great, no leaks. I only did the passenger's side for now. Might do the driver's side tomorrow, but the passenger's side was the one with the big, stinky, oil leak -- had been smelling burnt oil for a while and noticed smoke coming from under the hood the other day, so I parked the car and drove my other one until I could get the valve cover gasket replaced.
Quick summary:
1. I used the Felpro gasket set for the Lincoln LS -- part number VS 50724 R at Advance Auto Parts. It cost around $68 but I had a discount code that gave me $15 off plus a $25 gift card to be emailed to me later this month.
2. The three bolts that are extended for snapping the plastic engine cover on require a deep socket, which I didn't have so I hope I got those torqued right!
3. The plastic connector for the wire that connects to whatever that thing is that sticks through the cam cover broke but just the clip, so it still works okay.
4. The nut on the stud that holds the air filter box down was stuck on the stud and came out stud and all (like it was a bolt). Had to separate the two before I could get it reinstalled.
5. One of the bolts for the cam cover doesn't stay in the hole like the rest of them. Don't know why. It was the top, rear one. I relocated it to the lower front for no particular reason. If it's supposed to be in a particular hole, please let me know and I'll put it there! LOL
6. I took photos but didn't post them since everything looked normal, including the tensioner.
7. Had a bit of oil in the front most spark plug well. Wiped it out. Doubt that it'll be an issue, but will keep an eye on it. I decided to not change the plugs since I just did that a couple years ago.
Thanks for all the help! I couldn't have done this alone!
The following 2 users liked this post by OldMike:
davemellor (07-10-2014), jimlombardi (03-09-2014)
Old 03-09-2014, 03:13 AM
Jhartz's Avatar
On the left side, the sticking point, for many, is the dip stick. I cut an "alley way" with a hack saw. Be careful not to drop anything inside the head, there is a large opening at the front where bits will fall into the oil pan, some use an oil rag to stop any thing (don't leave the rag in the engine -- while back, somebody had an oil pressure issue, opened the pan and found a shop rag). The other concern is the plastic water line from the tank to the radiator, very fragile. You would not waste money buying a deep well 10mm and deep well 5/16 socket; need them for every job, it seems. Harbor Freight practically gives dep well socket sets away.
The following 2 users liked this post by Jhartz:
jimlombardi (03-09-2014), OldMike (03-09-2014)
Old 03-09-2014, 07:00 AM
OldMike's Avatar
Thanks Jim -- I almost went out to get a deep 10mm socket but just didn't feel like making another trip to the store! I did look at Home Depot and the two auto parts stores that I went to and didn't see any.
Old 05-02-2014, 11:16 PM
RSpi's Avatar
I will be doing this first thing in the morning. I have read a few things about worn tensioners. My brother's car is a early '03 (built in 2/02), does it not have issues with the tensioners?
Quick Reply: Valve Cover Gasket Replacement - Need How To
