Common harness/connector for ambient air sensor & sidelight?
Old 09-10-2012, 09:29 PM
Joe Reed's Avatar
Default Common harness/connector for ambient air sensor & sidelight?
I actually have 3 items in the same area that are not functioning:
-Ambient air temp sensor (getting error code 12 on the HVAC system)
-Left front sidelight not getting power on the red wire, but the ground is good (presently running a jumper wire from the red wire to the right side lamp)
-Left from fog lamp is out (but haven't had time to check for a bad bulb yet)
Since all three of these are withing just a few inches of each other, do they share a common connector or harness....and can someone give me a hint where to look first? I plan on doing some exploring under there later this week, so any tips you have would be appreciated...
Razor
08-28-2019 08:34 PM
KarimPA
09-12-2015 08:15 AM
tberg
09-07-2015 07:32 AM
Corycarlo
09-05-2015 11:41 AM
KarimPA
09-03-2015 07:32 PM
Quick Reply: Common harness/connector for ambient air sensor & sidelight?
