Back seat removal HELP
Old 08-25-2008, 09:17 PM
Grim001's Avatar
Default Back seat removal HELP
Anyone have directions on how to remove the back seat on my 02 X type? I have tried to remove the rear seat and I am having problems. I can get the front clips off but it won't move after that. I think I see where it is glued down near the back of the seat. any good tips on this. I need to run wires to my radio form the trunk and want to run them under the carpet in middle section.
Old 08-25-2008, 10:24 PM
queenmb's Avatar
Default RE: Back seat removal HELP
Check this out2003 VDP sub-woofer R/R?, not sure if its the same.
Old 08-25-2008, 11:48 PM
Grim001's Avatar
That is good, let me see if I can follow it and actually get my back seat out!
Old 08-26-2008, 07:51 PM
totally different on your car.. x type seat is held in by 2 clips in the front .. then the seat has to be pushed in towards the trunk area about a inch .. then it comes out .. seat has a metal ring.. that gets pushed into a hook type thing on the body..
Old 08-26-2008, 08:00 PM
queenmb's Avatar
My bad. Glad to see youre back jag genius. We may tear something up trying to do things on our own.[sm=oopssign.gif]
Old 08-26-2008, 09:02 PM
Grim001's Avatar
Thanks Jag Genius
Old 08-27-2008, 07:01 PM
welcome
Old 08-28-2008, 11:35 AM
gupdah's Avatar
I have a 2003 X-type 2.5L. IS this the same process of removing the seat? I tried to push it towards the trunk area. Do i lift and push or just push while it is in the regular position? Also my seats go down from the trunk, should i push them down than push the base towards the trunk or leave them closed?
jehart49
09-12-2015 05:36 PM
brgjag
General Tech Help
17
09-09-2015 07:34 AM
tberg
09-07-2015 07:32 AM
dcvickers
09-02-2015 06:14 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: Back seat removal HELP
