How often on oil changes?
The Owner Handbook should tell you the interval, but on my car, an X350 petrol V6 saloon, it is every 10,000 miles or yearly, whichever comes up first. I don't think the XF is wildly different to this. Funnily enough, cars with the diesel engine are allowed up to 15,000 miles.
Arlingtonman, I believe you bought your car from chantilly J/LR? I bought mine there to and my service interval is every 5k miles or one year.
Do not hesitation on oil changes. Good consistent oil changes does wonders for your engine. It helps it perform at high efficiency levels. This will help the engine stay cool, and clean. And clean engine runs smoother and helps the gas mileage. I would change my oil every 4/5 months.
I got mine at Bobby Rahal J/LR/Volvo. Best move I made.
Oil change is 10,000 miles for conventional oil. No need to use synthetic to go that far. Once per year maximum time interval. Jaguar does not use synthetic but I recommend that you do.
Do not change your oil more often than specified by Jaguar. . It is environmentally unsound, a waste of money and does absolutely nothing for your engine. Anyone who thinks differently is living in the past.
Oil is better, engines are much cleaner and filters are better. In fact filter life is now the concern. Newer filters can go up to 20,000 miles and two years.
Diesels are cleaner than they've ever been. They also do not have high inertia loadings because they rev so low. The most load goes on the oil film at high rpm on the exhaust stroke. The other end of the rpm range is lower loading but the oil film is weaker due to lower journal speeds, lugging is bad for an engine because the journal speeds are low not because of vertical loading.
richper (06-23-2012)
Received 6,249 Likes
I change my own, its no big deal. On my SC the engine cover simply lifts off. There is a large tray under the engine that must be removed but it is just a matter of removing some bolts and nuts. Drain the oil and change the filter just like on any other car.
I must be living in the past as I change my oil at 5k miles or one year whichever comes first. Gives me peace of mind, I enjoy doing it and it doesn't cost much.
Received 2,255 Likes
Not as much as people who change at 3K miles. There's no evidence that the factory intervals are too adventurous. I think almost all (most?) new cars today state 10K between oil changes.
Oil is better and engines run very clean now. No lead in the fuel and no excessive fuel enrichment means the main issue is contamination by water condensation.
Studies have been done that show there is no practical mileage limit if using fully synthetic oil. Only the heat/cool cycling which induces condensation and lack of filter capacity limits the change interval to one year. Mini specifies two years and my last Audi filter was a 2 year 30,000 km filter.
Agree, synth oil is remarkable
I have to side with Jagular on this one. Americans have been sold a dummy (as us Euro "soccer" fans would say). I have long been puzzled why the same manufacturer will recommend a longer oil change cycle on the same car, depending on where it is sold. 5k is way too often for any car and as has been said, it is environmentally unsound. If you choose to buy a big V8 (and I do) then it is incumbent upon you to find other ways to save the whales etc. (and I do).
Good, modern oils don't break down with use, it is as simple as that. I agree also that filters are probably the bottleneck and the main reason to change oil. I am a bit worried for Rique's car that a change of oil had such a profound effect on how smooth the running felt! Yikes!
No! I'm not doing that myself. It has that big underbody protection panel and it's just not worth it. However, I don't go to the dealer either. I just found a good local shop that knows what they are doing and have them put in synthetic oil and change the filter.
Oil change
Recommended oil change intervals were different on the 4.2 litre and 5.0 litre engines. I believe the recommended interval was 10K on the 4.2 litre and 15 K or 1 year on the 5.0 litre. The oil in the 5.0 litre has been the subject of some debate in this forum. It is not obvious whether it is a synthetic, a combination of synthetic and standard oil or standard oil from the part number and description.
My BMW uses synthetic pure and simple and requires a change every 1 year or when the service indicator shows a need for a change (this depends on how you drive the car and the conditions under which the car is operated) whichever comes first.
I tend to agree with Jagular on oil changes. Although there are a lot of differing opinions on whether more frequent oil changes help, the old reason, which was due to more rapid oil break down and the fact that engine tolerances tended to result in more metal in the oil, are no longer valid. The manufacturer has done a lot of research and unless the marketing guys came along and told them that they had to have longer intervals between changes, I will go with the manufacturer. I am sure that if these cars needed new engines after 100K miles due to servicing when the manufacturer recommended , there would be serious consequences in the market place. I try not to second guess the engine designers.
