Jaguar x-type fueal injector and fuel rail change
Old 05-07-2012, 04:58 PM
zibby_uk's Avatar
Thumbs up Jaguar x-type fueal injector and fuel rail change
Hi Guys
I recently had my Fuel Injector and Fuel Rail changed. I have attached images you might find helpful.
Whoever does the changes I have done make sure of one thing that the bolts should not be tightened beyond 10nm. Its not a very difficult job if you have a little skill. All you need is good weather and a weekend. You can save lots of money.
ThankYOU
The following 2 users liked this post by zibby_uk:
Panthro (11-03-2020), tc01 (10-17-2014)
Old 05-19-2012, 08:10 PM
DragonKat's Avatar
zibby did you have to do any programing for for the new injectors? I'm looking to replace on bad one.
Old 06-09-2012, 04:12 PM
zibby_uk's Avatar
Post
hi
first of all im so sorry for not replying i have just logged in after so long
if you are puting the same jaguar part replacement you do not need to reprogramme because the ECU already has been programmed for this part.
hope that helps
sorry once again
Old 02-12-2021, 01:11 PM
ugotmale's Avatar
Resurrecting this one. Dumb question, maybe not dumb, but seems dumb.... Is the fuel rail under pressure, or is there anything I have to do about fuel pressure if I replace the injectors? I'm having to dig in to the top end to replace a knock sensor and though I'd replace the injectors while I was in there. Feedback is always appreciated!
Old 02-13-2021, 11:01 AM
TonyJ1977's Avatar
Yes it will be under pressure. If yours is a model that still has the shrader valve then you can place a rag over it and press in the valve and relieve the pressure before taking it apart. If not then you can also pull the fuel pump fuse and crank the car for a few seconds and that will also let the pressure off
ugotmale (02-14-2021)
JagZilla
08-10-2022 10:26 PM
Innovative Detailing
Detailing / Car care
07-10-2010 03:57 AM
01-20-2010 03:38 AM
BuckMR2
05-28-2008 03:47 PM
Quick Reply: Jaguar x-type fueal injector and fuel rail change
