97 xj6 gas pedal sticking, not engaging ?
Old 03-25-2012, 09:47 PM
hawaiianjag's Avatar
Default 97 xj6 gas pedal sticking, not engaging ?
Let my xj6 sit a couple weeks in rain and now gas pedal not engaging, when I press pedal I can push it all the way till I feel the pedal stopper on the floor without it giving the car gas? Any ideas?
Old 03-27-2012, 07:46 AM
Roger95's Avatar
Check the throttle cable and return springs on the top of the throttle body.
Old 03-27-2012, 08:43 AM
Received 7,878 Likes on 4,762 Posts
Common fault.
bob gauff
The following 2 users liked this post by motorcarman:
Cadillac (03-28-2012), EZDriver (03-28-2012)
Old 03-27-2012, 10:54 AM
Either the cable broke if it goes to the floor or the ball end came out of the throttle. If its stuck like bob linked you on the tsb, and you pushed it to the floor forcing it. You just bent the crap out of the bracket and streached the cable
Old 03-27-2012, 03:16 PM
Hopefully it has Traction Control and the control box absorbed the stress.
bob gauff
Old 03-27-2012, 03:47 PM
Lol. We wont mention the whole black plastic nut, and tie strap i wrote about and what to do and then posted. Only to realise we're talking about a 97. Had to edit and rewrite and delete
Old 03-27-2012, 09:16 PM
Thanks a lot guys, it's not stuck to the floor I can push it down till it hits the ball but no gas given
Old 03-28-2012, 06:51 AM
Roger95's Avatar
Open the hood and check the throttle "linkage" on the top of the throttle body.
It's the driver side of the car right out in plain view. What you describe points to a problem in this area and if the throttle cable is broken or disconnected or the throttle assembly improperly installed it won't operate. Have you had recent work done on your car?
If the gas pedal sticks at off-idle then Bob Gauff's advice would apply.
Good luck
Old 03-28-2012, 09:55 AM
sharay38's Avatar
I've had the same thing happen on several occasions. All I ever did was manually move the throttle linkage by applying a slight upward pressure while turning it. Every time, it's freed the linkage. It's been over a year since the last time it stuck.
TXJagR
06-20-2016 01:02 PM
tonyforman
09-10-2015 07:23 PM
AtholC
09-09-2015 09:07 PM
hen555
09-07-2015 11:13 PM
giandanielxk8
09-06-2015 07:21 PM
Quick Reply: 97 xj6 gas pedal sticking, not engaging ?
