Red Brembo/R brake caliper paint code
Old 03-05-2012, 11:51 AM
Frog's Avatar
Default Red Brembo/R brake caliper paint code
My OE red calipers had a couple of paint chips in them, but I had not been able to find any touch-up kits or references for the exact 'Brembo' colour.
A few years ago I used to drive a red Fiat Panda and still had the touch up kit for that. Tried it on my calipers yesterday and it is an EXACT match. I waited until today to post this in case the paint changed colour slightly on drying, but it's fine.
The Fiat reference is Tiziano Red, code 199.
Kits should be available from all Fiat dealers or motorfactors, at least in Europe.
MarcB (05-27-2012)
Old 05-27-2012, 07:35 PM
MarcB's Avatar
Thanks Frog! I was just starting to research a touch up paint for my calipers today. Now, we just started seeing Fiat dealers again in the states so I am not sure how successful I will be but I am curious:
Has anyone else has touched up their factory red calipers with pain readily available in the U.S.?
P.S. I like your updated "R" badge, nice touch!
Old 05-27-2012, 08:15 PM
vettegood's Avatar
Hello, VERY nice wheels, BEAUTIFUL!
I just did my calipers and supercharger with G2 high heat caliper paint and it is the exact same bright red colour as the Jaguar Brembo brakes.
You can see my new thread and my older thread of my XKR modifications. new includes the supercharger and old includes calipers and drums.
Here are the links.
https://www.jaguarforums.com/forum/x...ication-74049/
and
https://www.jaguarforums.com/forum/x...tioning-72253/
G2 website
G2 Brake Caliper Paint Systems
Happy Motoring...
Old 05-27-2012, 08:45 PM
ccfulton's Avatar
Received 1,106 Likes on 763 Posts
Originally Posted by Frog
A few years ago I used to drive a red Fiat Panda...
From a Fiat Panda to an XKR, now that is quite a change.
Old 04-02-2013, 07:38 PM
LORENZ's Avatar
Frog, do u think the g2 paint is the same as the Fiat paint code 199 that ur referring to. Im ready to pull the trigger on buying paint untill i read your thread,,,thanks Frog
Old 04-03-2013, 01:31 AM
Frog's Avatar
I can't be sure as paint brands can vary slightly. Why not order the real Fiat paint online?
Old 04-03-2013, 07:29 AM
LORENZ's Avatar
yea i agree with you. but so far all ive seen was touch up bottles. I need enough to paint all 4 calipers. Have you seen where i can but a pint or quart
Old 04-03-2013, 11:36 AM
Frog's Avatar
If you are completely repainting all 4 calipers, then I guess an exact colour match isn't vital. Any vaguely similar red should do.
Old 04-03-2013, 01:12 PM
LORENZ's Avatar
The red you have on ur calipers above is exactly what im looking for. Do you know a good place online to buy it? Thanks
Old 04-04-2013, 01:34 AM
Frog's Avatar
TBH, I would just get some heat-resistant red paint from a local automotive suppliers. The problem is that if you just paint standard calipers, they look a bit cheap & nasty:
Ideally, to get close to the original factory finish, you should remove the calipers completely and get them powder coated, but this is way more complex.
Attached Thumbnails Red Brembo/R brake caliper paint code-paintedcalipers01.jpg
Old 04-04-2013, 10:22 AM
LORENZ's Avatar
Well i like the Tiziano red, and also the Rosso Corsa red thats on the Ferrari. Those seem to be the best colors for red to me on a caliper. Just not sure the best place to get it. Does this place Automotivetouchup.com place have a good rep or that other place i think its called need4paint over in the UK. Thanks
Old 04-04-2013, 10:54 AM
tberg's Avatar
Received 2,541 Likes on 1,412 Posts
Lorenz,
For under $20 you can purchase the Duplo Caliper Paint Kit in the bright red shown on my calipers below. The Jaguar vinyl lettering was purchased online for $5.98 (silver metallic lettering). (These were done about 3 weeks ago) After the paint has dried and the lettering applied, they were sprayed with an overcoat of clear enamel. Under $30 total investment. If you have the Brembo brake option, the Brembo vinyl decals are available as well in place of the Jaguar lettering. Since you're painting the entire set, identically matching color shouldn't be an issue. As I recall, however, the Brembo red is a bit more orange red than these. However, the Ferrari calipers are red like this as are the Wilwood racing calipers (I have them on my Pantera).
Attached Thumbnails Red Brembo/R brake caliper paint code-dscf0942-600x800-.jpg   Red Brembo/R brake caliper paint code-dscf0927-800x600-.jpg   Red Brembo/R brake caliper paint code-dscf0943-800x600-.jpg
Frog's Avatar
Available on Amazon here. Seems to have good reviews.
Old 04-04-2013, 03:12 PM
LORENZ's Avatar
Originally Posted by tberg
Lorenz,
TBERG, looks great. You did a pretty good job there and the red looks pretty bright to. Thanks
mawheele
10-07-2020 05:38 PM
JagBrian
08-18-2019 05:07 PM
cissdm
05-03-2016 06:02 AM
WinterJag
16
10-09-2015 07:49 PM
philwarner
09-05-2015 10:05 AM
Quick Reply: Red Brembo/R brake caliper paint code
