03 X type P0442 code
Old 01-05-2012, 01:03 AM
funkdoktor's Avatar
Default 03 X type P0442 code
p0442 (Evaporative emission system leak detected (small leak)) code is triggering my check engine light to come on. Is this a common problem for x type's? If so, what are some things I can take a look at to diagnose what is causing it?
My car runs fine right now but I'm just a little worried about running into future problems if this is not fixed. I just had the upper radiator hose & coolant reservoir tank replaced maybe a month ago & this is one of the codes that popped up after fixing those. There was one more which was a p0174 (system too lean (bank 2)) code that showed up but did not appear once again after clearing it after my repairs.
If anyone can give their insights on what I could possibly look for or check out I would greatly appreciate it.
Mahalos.
toronadomike
08-07-2022 03:41 PM
prettydaim
03-28-2021 07:47 AM
Shawn Svacha
11-04-2019 02:47 PM
David Thompson
09-03-2015 07:48 PM
dcvickers
09-02-2015 06:14 PM
Quick Reply: 03 X type P0442 code
