jag won't start!!!!!
Old 11-09-2011, 06:25 AM
SchultzLD's Avatar
You really need to post the codes on here. You'll get better help. Some of the Members on here are VERY knowlegable about these cars. But so far it could be so many different things.
Old 11-09-2011, 07:24 AM
JagV8's Avatar
I'd fix the things you're fairly sure are wrong and also check for oil/water/etc in plug wells. Be sure you know the right cyl numbering (see prev posts, JTIS, FAQs).
But also look up
bore wash
and be very aware of it
The codes are only of use to say which cyls unless you have other codes too.
Check your PATS light is doing what it should (again prev posts, JTIS etc).
If your fuel filter's old, change it.
Old 11-12-2011, 12:33 PM
fastest94v6's Avatar
Double check some grounds! Usually when a car is backfiring then that may indicate a ground issue.
1964Daimler
09-02-2015 11:41 PM
Rusty1952
09-01-2015 05:45 AM
cheaperts
08-30-2015 06:48 PM
Drew2006
08-28-2015 04:22 PM
SingBlueSilver
08-27-2015 02:20 PM
Quick Reply: jag won't start!!!!!
