Power Steering Fluid
Old 04-15-2008, 01:25 PM
mep's Avatar
mep
mep is offline
Default Power Steering Fluid
Is there any alternative to Jaguar power steering fluid that can bought in a regular auto parts store?
Old 04-15-2008, 07:21 PM
Default RE: Power Steering Fluid
mobile one synthetic.. i guess you can look at anything similar at a auto parts store.. make sure it meets or exceeds.. the jag fluid.
Old 04-15-2008, 08:45 PM
Dennis's Avatar
ud
This is what the JTIS says..but the dealer gave me a bottle of Mobil Premium ATF...has there been a change of fluid requirements?...Something in the my memory banks I recall, that the guys at the dealer said there was a change...and it was pricey too..
Power Steering Fluid: JTIS Spec: Mobil ATF meeting Dexron 3 Specification. Capacity: 1.2 Qts. Approximately
Old 04-16-2008, 11:00 AM
mep's Avatar
mep
mep is offline
I went with Mobil 1 Syn. ATF.
Thanks for responding.
Old 04-16-2008, 08:28 PM
reddrawf's Avatar
How often should it be changed? I just had my oil changed and they said the power steering fluid should be changed too.
Old 03-06-2013, 11:25 AM
Cabotom's Avatar
Default Changing my fluids and filters. Specifications?
I have a 2005 S Type 3.0 6 cyl. I live in Cabo San Lucas, Mexico and they so far don't have the air filter I need. So I'm going online and having it all sent here. I want to get P/S fluid, Air filter, gas filter, *Do I need transmission fluid and filter or are these transmissions sealed? I also need Rear end fluid & Cabin Filter (whatever those are? It was suggested I change these in a different post.) And I might as well snag some spark plugs and engine oil while I'm at it. Anything else I might need that they won't have in my area which I'll just assume is everything and anything? This car was not maintained and so I want to get it up to par... What are the special SPECIFICATIONS on each? And is there a way to buy these at Autowharehouse and not have to buy from Jaguar?
sogood
09-15-2015 07:35 AM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 04:03 PM
1964Daimler
09-09-2015 11:28 AM
MrMellor
09-07-2015 10:22 AM
AL NZ
09-04-2015 08:39 PM
Quick Reply: Power Steering Fluid
