Self closing sunroof
Old 03-30-2011, 12:50 PM
JagLoverX2's Avatar
Default Self closing sunroof
I open my sunroof, in either the slide or tilt position, and it "automatically" closes itself after a matter of 10-30 seconds. I do not push the button to close it, I'm thinking it may be a sticky connection or loose wire in the switch. Any others have a similar experience and find a solution? Thanks, Roger
Old 03-30-2011, 01:13 PM
SirJag's Avatar
Interesting. Sometimes when I close mine and it's "self-closing" (meaning the 1-touch operation), it stops a few inches short of being fully closed and begins reopening.
Also, mine doesn't seem to automatically open with one touch.
Maybe someone can shed some light on this for us.
SirJag
Old 03-30-2011, 01:16 PM
yeldogt's Avatar
Does it look like the roof is fully opening? -- The roof will reverse if it thinks it is hitting something.
The tracks need occasional lubrication. Needs to be the correct grease and not too much.
Also, be especially careful that the roof has fully closed. For two reasons: (1) it will leak and (2) if the roof is not in the correct "closed" position when you try to open it to the vent position -- the plastic clips in the track can break.
Every sunroof in all my Jaguars have been a problem -- all have required some work. I never use the tilt feature -- the clips have broken is all three of my recent ones -- unbelievable pain to fix.
Old 03-30-2011, 01:44 PM
JagLoverX2's Avatar
Yes, sunroof is fully open, it stays open for a few seconds, the closes, what is the correct lube? Can I use lithium grease? I have used this on sunroofs on other cars.
Old 03-30-2011, 02:20 PM
yeldogt's Avatar
Thats strange -- I wonder if it has limit switches and if they require adjustment?
I do not know what the proper grease is -- I use a tube of Mercedes sunroof grease - it's not very expensive. It does not look like a typical white or Lithium grease. Often many of the lithium greases are too thick for.
It is light like the stuff for a garage door opener. Lubriplate - sells a garage door product that is lighter than the more common white product.
You need to clean the track off as well - just be careful -- lots of plastic pieces.
Old 03-30-2011, 02:42 PM
burmaz's Avatar
Maybe recalibrating the sunroof module will help? You can actually get the sunroof to fully retact instead of the usual 75% opening if you play around with it. I worry it will break something when it goes all the way back into the roof, as if it could break the track.
Old 03-30-2011, 03:45 PM
yeldogt's Avatar
I just gave it a look on my way to the bank -- the grease is almost clear -- looks like a thick Vasoline.
Same color as the Jaguar stuff.
Old 10-06-2015, 05:30 PM
King Charles's Avatar
Received 1,019 Likes on 740 Posts
Mine is closing on it's own as well, I recently had the headliner done & the back drain duct reseated whilest doing so. Is mine a lube issue, it does give a loud pop or 2 opening or closing.
hkmcmast
11-29-2015 06:56 AM
JungleJonny
10-05-2015 03:52 PM
millertic
09-30-2015 08:11 PM
Quick Reply: Self closing sunroof
