2000 v8 engine swap
Old 02-11-2011, 06:14 PM
2000v8's Avatar
Default 2000 v8 engine swap
I have a 2000 4.0 s-type and the engine seized up on me. I want to drop in a new ford dohc 5.0 but don't know if it is possible. If not what would i need to drop in a new jaguar 5.0 and where can i find one
Old 02-11-2011, 06:30 PM
vance580's Avatar
Alot more money then the car is worth. The new ford 5.0 and the Jag 5.0 are alot of money to just get the engine alone then to get it to fit and all the other stuff you would probably be better off just buying a new 5.0 mustang. Would actually probably be cheaper.
Old 02-11-2011, 06:45 PM
2000v8's Avatar
The new ford 5.0 and modular control packs and wiring harness would be under 9k. I just bought a new tranny and it has less than a thousand miles on it. I love s-types but the engines just don't last. The one that seized up had 68,000 on it and it was maintained very well. I guess what I'm trying to ask is if the tranny would match up. I know in 2000 jaguar was owned by ford and the lincoln ls and s-type are very similar.
Old 02-11-2011, 08:18 PM
vance580's Avatar
Once again you are gonna drop 9K plus what you paid for the trans. Then you throw in all the wiring that you are probably gonna need an electrical engineer for. You are gonna have to try and wire the 5.0 with all the Jag systems that are already in the car. Then you are gonna have all that power in a 2000 regular S-type so you are gonna need to upgrade the suspension and the brakes so its safe. This is assuming you do everything yourself. When if you took all that money and just get a STR you will pretty much have the same thing for cheaper. You can get STR for under 20000 easy. I've seen good ones for 15000 and lower in some cases. Just gotta be patient and keep your eyes peeled.
Old 02-11-2011, 08:24 PM
vance580's Avatar
Kinda curious what makes you think your engine is seized. If it was well maintained like you say its hard to believe it would seize at 68000. Did a shop tell you this? What was the car doing that would make you think this?
Old 02-12-2011, 02:07 AM
2000v8's Avatar
I've had the car since it was new and changed the oil every three thousand miles. It had an oil leak problem, I've heard it's pretty common with the 4.0. I changed all the gaskets and got new valve covers and that seemed to stop the leak problem. While it was leaking I got a check engine code regarding a lifter and had that one changed even though it looked fine. I talked to a jag specialty shop and they told me it was probably a low oil level that triggered the code.
The other day the check engine light came on.I went to the store the next day and when I started it to go home the engine was knocking hard. I had it towed to my regular shop and when we started it up there it idled for a little while and then seized up and now won't even turn over.
Old 02-12-2011, 02:47 AM
JagV8's Avatar
What!!! The engines don't seize at all often. Did you have the revised tensioners (& guides) fitted?
Threads here and elsewhere to read (use Search) if not.
If you're going to change engines, your only realistic option is the exact kind you had, so another 4.0. Otherwise cheaper to buy another car.
Old 02-12-2011, 05:55 AM
bfsgross's Avatar
2000v8, it's an STR for you!
Old 02-12-2011, 07:16 AM
Enthusiast's Avatar
If you want to keep it, I would just rebuild the engine that`s there. Use good parts, perhaps bore it out......you know everything is going to fit and it`s going to be cheaper than buying a new unit and trying to make everything work together.
mikiep
12-20-2019 07:37 PM
bdboyle
09-16-2019 05:58 PM
inactualis
10-02-2015 11:13 AM
Poet
10-02-2015 09:00 AM
ziondio
10-01-2015 01:48 AM
Quick Reply: 2000 v8 engine swap
