Gas Door Clip
Old 02-02-2011, 11:16 AM
drevvp24's Avatar
Default Gas Door Clip
The clip broke on the inside of the gas door which latches to the inside by the actual fuel cap. Where can I buy a replacement? This is for a 2001 XK8. Thanks!
Drew
Old 02-02-2011, 12:32 PM
WhiteXKR's Avatar
It appears they only sell it with the entire fuel door.
Part number FJA3089AG
These guys let you search by part number : http://www.gaudinjaguarparts.com/par...&siteid=214626
I am out of town so I cannot look at my car...maybe someone else can chime in on how easy the clip is to remove from the door, because otherwise you would have to have the new door painted.
Also, it is still best to call whichever dealer you buy from and give them your VIN to be certain of the correct apart.
Also these guys also have lots of used parts:
https://www.jaguarforums.com/forum/s...ad.php?t=45392
Old 02-02-2011, 05:52 PM
Easily replaceable..... by itself.
P/N HJA3097AD
WhiteXKR (02-02-2011)
Old 02-03-2011, 11:47 AM
Spurlee's Avatar
Default JB Weld
The retaining tangs on mine broke off and I simply used a little bit of JB Weld to reaffix it to the fuel door. The JB Weld filled the void between the flat side of the retaining clip and the curved fuel door. Cheap, easy, fast and (if you are neat) no one will ever know.
Old 02-07-2011, 04:49 PM
jnporcello's Avatar
Hey bro,
Good luck trying to repair your gas tank door. I think you need to get your hands dirty and give it a try
Welcome to the forum
Old 06-12-2014, 11:05 AM
jackbrunner's Avatar
where can I buy the pin kit for fuel door? Jaguar s type 2005
GordoCatCar
01-02-2017 01:10 PM
XJsc-guy
11-23-2015 01:56 PM
SeanU
09-14-2015 04:31 PM
jagent
09-12-2015 09:10 AM
sadepol01
09-11-2015 05:26 AM
Quick Reply: Gas Door Clip
