Codes P0171 & P0174
Old 12-15-2010, 07:20 PM
John Mac's Avatar
Angry Codes P0171 & P0174
Hi Guys my 2004 X type 2.5 just thru these codes .I had new plugs fitted 2 weeks ago at a cost of $425.00 Ouch. Did not want to tackle that job myself.
Vehicle is running fine just annoying that the check engine light is on.
Local Auto Zone pulled the codes and said is was the Bank 1 upstream CO2 sensor and the Bank 2 Downstream CO2 sensor. Running Lean
Checked on the forum and found it could be a Dirty MAF sensor causing the codes to appear. Were is the MAF sensor and any tips on how to clean it.
John
Old 12-15-2010, 08:33 PM
mohrd's Avatar
lots of discussion about vacuum leaks at this time of year, every year. do a quick search on those lean codes and you'll see discussions around three likely culprits that are easy to check and fix.
bdboyle
09-16-2019 05:58 PM
JCam
10-23-2016 08:27 PM
Bob Gelston
09-14-2015 11:08 PM
OkieTim
09-08-2015 04:48 PM
OkieTim
09-02-2015 12:48 PM
Quick Reply: Codes P0171 & P0174
