02 S-type No Heat, Core not clogged
Old 11-20-2010, 06:45 PM
dericksmith's Avatar
Default 02 S-type No Heat, Core not clogged
I bought this thing without testing the heat (it was August in Phoenix). Anyway, I've been reading all I can to diagnose the problem. I back flushed the heater core, it was clean. However, with the engine hot, only one of the three lines is hot. If I understand correctly, the top two go IN to the heater core, the bottom, large hose is coming OUT of the heater core. The weird thing is, only the BOTTOM one is hot! Am I wrong about the bottom one being the OUT? Any advice?
Old 11-20-2010, 07:05 PM
bfsgross's Avatar
You may have one of three issues to sort through. 1. First determine that there is no air trapped in the coolant system. 2. In the engine compartment down low on the front passenger front of engine there is an electrical solenoid operated coolant diverter called the "dual climate control valve" (DCCV). This can fail and you'll not have proper heat or a/c control. 3. The climate control module (CCM) may have failed too. It is attached to the back of the climate control station on your dash. Check the many threads of this forum as a means to educate yourself on sorting through this issue. You'll do just fine.
Old 12-06-2010, 12:23 PM
Default Update
I have replaced the DCCV (heater valve). Flushed the heater core - excellent, clear flow out of all three lines. All three lines get hot, but ice cold air blowing when I have the heat on. Everything else with the climate control system works fine. Just can't get any heat. If I take the #1 fuse out (for the heater valve), I can hear the valve either open or close, then I can hear it again when I re-insert the fuse. My temp guage never goes past normal. I am at a complete loss here. I don't think it could be thermostat, could it? Any ideas?
Old 12-06-2010, 12:35 PM
JagV8's Avatar
As bfsgross said, check the many threads. Chances now are you have a faulty sensor or the CCM (climate control module). (A dealer-type tool can test these or you might throw money at it by replacing parts.)
Old 12-06-2010, 12:42 PM
If you pull the panel on the drivers side of the dash there is a connector for the dccv. I think on your car its pins 11, and 12 on the conn that has only 3 wires. Useing a dvom you monitor for ground and voltage. At full heat you should see batt voltage cause the valve is normally open and you see volt. As you drop the temp on the ac panel you should see batt voltage go away and ground come up. This is what closes the valve. I have a module for your car but its a (001) suffix on the vcats label in your trunk. Let me know what you find.
you can also unplug the dccv electrical connector and the valve should open
Old 12-06-2010, 01:55 PM
bfsgross's Avatar
Whoa Brutal...that was a good info. post, thank you.
Old 02-16-2012, 05:36 PM
75sausage's Avatar
Would you be so kind and elaborate on the exact panel location where the dccv connector is located?
Old 02-16-2012, 07:55 PM
Received 6,253 Likes on 5,453 Posts
Thanks to - JaguarClimateControl.com for the pic.
Old 02-16-2012, 08:14 PM
Gus's Avatar
Gus
Gus is offline
I do not know what MY car you have but this might help JagRepair.com - JDCCVSType
Old 02-17-2012, 07:32 AM
75sausage's Avatar
Thank you
Poet
06-07-2019 07:54 PM
emilime75
XJ XJ12 ( X305 )
10-19-2015 09:55 PM
3jagfamily
10-01-2015 01:49 AM
redgear
09-26-2015 07:21 AM
zdrapec
09-25-2015 05:49 AM
Quick Reply: 02 S-type No Heat, Core not clogged
