Performance parts for the XJR 6 cyl
Received 10,803 Likes
Lack of demand means not much by way of go-faster parts for these cars.
There is (was?) somebody out there making a crank pulley to speed up the supercharger but the couple people I've heard from were not happy with the results and went back to the original pulley. Initial power was improved but the increased heat caused a loss of power after anything beyond a short burst, it seems.
I think Mina makes an exhaust system (actually for the regular XJ6 but I guess it fits the XJR properly) that might help a little.
Another outfit....can't remember who right now....is (was?) selling a low restriction air intake but it didn't do much except draw hot air from the engine bay which is the last thing you need with a supercharger.
Anything you do do to keep the air charge cooler seems to work well, however. Until you can get it really cold, however, this is more a matter of keeping the horsepower you already have rather than making new horsepower.
Andy Stoddart, an ex-Jag engineer, sells a bracket to reposition the crank sensor and give more timing advance. It works well. Max power doesn't change but part trottle torque/response is better.
I changed from the 3.27 diff to a 3.58 and it made a decent improvement, especially coupled with the timing bracket.
DD
DD
I think I will get the timng bracket any link or ifo on where to get it?? I would like to put in higher gears as well thats always a nice effect on acceleration. The guy that is gunna tune it is a genius at tuig. He cracked the audi code, mercedes, and many others he tunes all of SVTs cars. Hes great and he said he can get me a nice jump in power with a tune, he says that jag is very safe with their tunes. I have a guy that custom makes all my exhausts and hes great so Ill be using him for exhaust go 2.5 all the way out with magnaflow muffs. I use to own a 91 supercoupe and built it nicely, I figure it would be easy to take off the blower and have it ported and put a smaller blower pulley maybe even upgrade the intercooler and up the boost a bit. Where do you get rear end gears is there a diff that fits with a better ratio?? Thank for the help also Im really shocked there isnt a chip for these cars hum
Also anything I should look at dont know the problem areas with these cars yet I drove it and it drives well for 102k, suspension feels good, runs strong too. I am gunna change all the belts, change the plugs too NGK plugs (my fav plugs), change fuel filter, oil filter, and a few other things to get it up to par.
I used to have an SC as well :-).
With your SC experience you know that there's not much point in increasing boost without upgrading the intercooling, as you mentioned.
Let us know if the exhaust really helps.
The 3.58 diff is standard issue on the standard XJ6. Might be hard finding one with limited slip, though. I got lucky on that one. Of course you can take the open 3.58 and install a limited slip carrier. The diff itself is a direct swap.
For the timing bracket go here http://xjr6.co.uk/ and look up a guy who goes by "XJREngineer". He has the brackets.
DD
DD
scottatl
09-04-2015 08:08 PM
