New Battery in Fob...Have to Reset Anything??????
Old 10-23-2010, 07:09 PM
390HPTypeR's Avatar
Default New Battery in Fob...Have to Reset Anything??????
Just put a new battery in the key fob as the remote obviously stopped working...new battery is in but the remote still isn't working. Anyone know if there is something that has to be done to reset the fob when a new battery is installed??? (any other suggestions appreciated as well!)
TIA...
Old 10-23-2010, 08:35 PM
Mafioso's Avatar
Im curious about the same
Old 10-23-2010, 08:51 PM
Gus's Avatar
Gus
Gus is offline
Received 2,206 Likes on 1,700 Posts
I cleaned and replaced remotes and batteries for my 99xk8 & 95xj6 and no reprogram. I am unable to speak for the s-type but I would assume it is the same. This is how I did it http://www.gusglikas.com/AutoRepairxk8Remote.htm Hope this helps!
Old 10-23-2010, 08:52 PM
Received 7,849 Likes on 4,749 Posts
Here are 2 TSBs I have for this fault. The one is for the X-Type but it may be relevent to the X202 also.
bob gauff
File Type: pdf
File Type: pdf
Old 10-23-2010, 10:21 PM
jag79's Avatar
[QUOTE=390HPTypeR;259970]Just put a new battery in the key fob as the remote obviously stopped working...new battery is in but the remote still isn't working. Anyone know if there is something that has to be done to reset the fob when a new battery is installed??? (any other suggestions appreciated as well!)
TIA...[/QUOTE
...hey this maybe very useful info for other S type owners encountering this same problem later on, please do give us an update and solution to what happened.
Thanks and good luck.
Old 10-24-2010, 08:15 AM
JagV8's Avatar
A fairly common cause is that the battery is either not making proper contact or is shorting out. There was a revision to add some foam to the inside of the fob. It's been covered before and is likely also in the FAQs / TSBs.
Old 10-24-2010, 11:11 AM
390HPTypeR's Avatar
I hope this is the case and can be corrected with a little bit of tinkering...the remote worked fine before so I thought the battery would obviously be the cause but a simple replacement is still not working...
I'll keep on looking into it and then let everyone know what comes of it...thanks to everyone for the replies...
Old 10-24-2010, 02:35 PM
DittoGlen's Avatar
I replaced batteries in 2 and had no problems.
Ensure the + and - are correctly aligned of course...
Old 10-24-2010, 04:24 PM
ohsigmachi's Avatar
Do you have a working fob?
If so do this:
take fob out to your car, insert key into ignition cycle from off to accessory on position 8, I repeat eight times rapidly (you have to go pretty darn fast). press the lock button on the fob that doesn't currently work, and then press unlock on the one that does.
If that doesn't work then you know it is an issue with the actual fob not putting out a signal.
Old 10-24-2010, 07:22 PM
Mafioso's Avatar
Even easier drive to autozone. They have a display for testing key fobs if it's transmitting the display will let you know it could be as simple as DittoGlen said battery could be installed backwards
Old 10-24-2010, 10:18 PM
ohsigmachi's Avatar
considering the nearest autozone is 5 miles down a super busy road, I fail to see how this is easier than sitting in my driveway turn the key a few times.
Further, if your key fob did lose its programming during the battery change the method I just outlined reprograms it. I doubt the autozone kiosk will do that.
Old 10-25-2010, 09:11 AM
Mafioso's Avatar
Just a suggestion since not everyone has RF receiver capable of scanning FOB frequencies at home. IDK to me it seems like a reasonable to Suggestion to without a doubt rule out a FOB transmitting or not, I mean even if the battery is placed in correct who is to say a trace didn't get broken and it's no longer transmitting.
I speak from experience with prestige remotes
Old 10-25-2010, 01:28 PM
390HPTypeR's Avatar
Went to Autozone, the fob is putting out a very small amount of frequency from the tester they had...so not sure what it is due to...
Old 10-25-2010, 01:58 PM
Gus's Avatar
Gus
Gus is offline
Are you sure you did not throw away the new and reinstall the old battery? If that is not the case get a new battery (RadioShack) and test the battery then.
Old 10-25-2010, 02:12 PM
Mafioso's Avatar
AH HA!!! making progress.
Old 10-26-2010, 10:27 AM
390HPTypeR's Avatar
Unfortunately, yes...the new Panasonic is in from RadioShack...
Old 10-26-2010, 12:10 PM
Mafioso's Avatar
reopen the FOB and clean the battery contacts and inspect for broken traces,
Old 10-26-2010, 12:39 PM
Gus's Avatar
Gus
Gus is offline
Did you try to clean the buttons as outlined on my page http://www.gusglikas.com/AutoRepairxk8Remote.htm
Dagny
07-20-2020 05:39 AM
99xk8guy
09-21-2019 07:34 PM
Will P
09-30-2015 08:38 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
DEklof
09-08-2015 05:28 PM
Quick Reply: New Battery in Fob...Have to Reset Anything??????
