XJ8 2005 P1251 code
Old 10-18-2010, 07:12 PM
bniland's Avatar
Smile XJ8 2005 P1251 code
I had a eng sys failure display along with DSC not available and Parkbrake failure the car went into limp home mode. Got it home scanned with my code reader it showed a P1251. Read the Forums and thought for sure I was going to need a throttle body.
I went on Justanswer.com and found a master Jauar tech Richard sent him my symptoms he suggested looking at the number 24 fuse in the engine compartment fuse box a 20amp fuse. It did not look blown but replaced it with a spare from the trunk the faults all wne t away and I could accelerate again. Turned off the check engine light with my scanner and all is good now. Thought I would share the experience $30 on Justanswer.com.
Bill
Old 10-18-2010, 08:40 PM
Gus's Avatar
Gus
Gus is offline
Received 2,208 Likes on 1,700 Posts
Good to know! After the fuse was replaced did you check the old one for continuity? Was just wondering if it was blown or just a bad connection.
Old 10-20-2010, 08:17 AM
oldmots's Avatar
Bill
The code you got is clearly a throttle motor circuit power problem, not the throttle body. A lot of problems get caused by incorrect code analysis. I suggest getting a subscription to Alldata.com so that you get the right information. If you had Alldata, you would have found this yourself and saved some worry,money and time.
Old 10-20-2010, 08:51 AM
Gus's Avatar
Gus
Gus is offline
Bill
What is fuse #24 designated for in your car? I do not have that information available to me and would like to better understand how it applies. I could not use AllData because it is year and car specific. This is an interesting find!
Old 10-24-2010, 01:03 PM
Ironically, I had this same thing occur to me last night. I left the car out front for the evening and check the boards this morning and found this thread. Went out to check the fuse but decided to start up the car anyway to see if problem persisted. It went away overnight. Gonna swap the fuse now to see if the problem re-occurs.
Loving this board!
Old 11-10-2010, 09:07 AM
Happened again last night, but in the car's defense, I didn't change the fuse like I said I would.
Changed the fuse and it runs fine, but now check engine light stays on. Is there a way to reset this light without buying a scan tool? If not, what scan tool do you guys recommend? I might as well get one.
Btw, checked the old fuse for continuity and it seems fine - maybe it's just getting old?
Old 11-10-2010, 02:37 PM
Gus's Avatar
Gus
Gus is offline
I am not convinced that the problem is the fuse. I find it strange that when you are fooling around with the fuse box it runs. Check the code and see what comes up. My suggestion is to check all your connections from the battery to the fuse box and make them clean. Oxidation on the connections can play games with you. If you elect to do this first disconnect the battery and at the same time check the grounding connections. Keep in mind that a bad connection can cause a code.
Old 11-29-2010, 07:12 PM
Happened again. Needs a new throttle body. But my warranty covers me (EasyCare TotalCare pkg). And my dealer is taking care of a couple of other things under the warranty too!
caveforce
38
11-16-2015 10:19 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
corysansburn
09-10-2015 06:15 AM
TexasCat
09-08-2015 04:36 AM
rachelstr
09-03-2015 12:59 PM
Quick Reply: XJ8 2005 P1251 code
