Code P1111
Old 04-22-2010, 04:09 PM
cole1072's Avatar
Default Code P1111
I have a 2003 XJ8 Sport which occassionally comes up with a Failsafe Engine Mode reading. I took the car to Autozone and they said it was a P1111 code reading. I have been told that it could be related to an Intake Air Tempature Sensor but I can't even find that part listed for my vehicle. This problem only occurs randomly but when it does I have no Cruise Control. Any help would be gratly appreciated!!
Thanks,
Jeff Cole
Idaho falls, Idaho
Old 04-22-2010, 05:43 PM
steve11's Avatar
ud
Hi,
P1111 is not a fault code. It is a special designator Jaguar uses meaning system ready, drive cycles completed after the last fault event. P1000, on the other hand, means system not ready, or drive cycles not completed after the last recorded fault event.
Some OBD II Basics - All P0xxx codes are generic and uniform across all manufacturers and mean the same on every car. All P1xxx codes are manufacturer specific codes. You cannot use a generic code chart to analyze P1xxx codes for a Jaguar.
Next time your car displays an engine fault light, try reading the codes then. If you have a CEL illuminated and the only code read is P1000 or P1111, then you probably have a fault that generic code readers cannot see. Could be a chassis code, for example.
One last thing - Neither P1000, nor P1111 can be erased.
Hope this helps you.
Best,
The following 2 users liked this post by steve11:
Catenaccio (01-20-2014), texasjono (05-24-2017)
Old 04-23-2010, 10:05 AM
cole1072's Avatar
Thanks!!!
Old 07-15-2010, 08:09 PM
pdog2000's Avatar
many thanks...this explains the P1111 and P1000 i was just getting...i got the P1000 after i cleared the P1111...now it all makes sense...thanks
philwarner
25
06-26-2021 05:43 AM
bdboyle
09-16-2019 05:58 PM
Terry H
07-04-2017 05:48 PM
JCam
10-23-2016 08:27 PM
philwarner
09-02-2015 11:45 AM
Quick Reply: Code P1111
