Seat control module
Old 09-26-2010, 07:19 PM
Gus's Avatar
Gus
Gus is offline
I would love to see this seat problem that everyone is talking about. I saw Sam’s video on this but would like to see it close up to better understand the problem.
  #62
Old 09-26-2010, 08:03 PM
D3RAW's Avatar
Are there any photos around of the usual traces that break?
Or is it just a case of getting a magnifying glass and looking?
Drew.
  #63
Old 09-26-2010, 08:15 PM
Gus's Avatar
Gus
Gus is offline
If you are speaking of the seat module try one of the two http://forums.roadfly.com/forums/jag...9317317-1.html or http://www.jag-lovers.org/include/iv...aYyDO5FA%3D%3D If you are looking to repair the headrest use this link https://www.jaguarforums.com/forum/s...ad.php?t=40347
  #64
Old 10-21-2010, 10:51 AM
XKR Brian's Avatar
The case is availible seperately. As far as repairing these I dont know how to solder the circuit on the board but I have had great sucess soldering a wire from the origin of the tracer to the destination. Due to the inherent cause of this concern being the case wearing on the circuit board this repair would be eliminating the cause.
msimowitz (06-15-2012)
  #65
Old 09-22-2011, 02:52 PM
XKR Brian's Avatar
anyone out there needing this addressed. I have pretty much found all the answers to what goes wrong with these by now. If anyone wants theirs fixed I can perform this service.
  #66
Old 02-04-2012, 06:46 PM
Gary Horton's Avatar
Originally Posted by JagtechOhio
I have early modules in stock. What year is your XK8?
Hi there.
I have a bad seat control module for a 2004 XK8, # lje2160ab/xxx. Might you have or sell replacements? Or fix?
Thanks... what is your direct contact info?
Gary
  #67
Old 06-15-2012, 09:42 AM
msimowitz's Avatar
Did you find out if parts are interchangeable. I put the older part in mine and seat heater won't work but everything else does. Does the module control the seat heater?
  #68
Old 06-16-2012, 04:12 AM
H20boy's Avatar
The seat heater wiring goes through the module IIRC, but there is also another connector to the heating elements wayyyyy back under the seat, almost where the cushion meets the seat back.
  #69
Old 06-22-2012, 01:52 PM
msimowitz's Avatar
do you have LJE2160AB/XXX
  #70
Old 06-22-2012, 02:04 PM
msimowitz's Avatar
I replaced part LJE2160AB/XXX seat module with part LNC2160AD/XXX because seat would not move backwards. Now with the new part the seat heater doesn't work but everything else does. I switched the driver's seat module and the heater works on both seat with that module. So does the new part not have the heater capacity or is it programmable and if so how do I program it? Otherwise, anyone got part LJE2160AB/xxx?
  #71
Old 06-22-2012, 02:17 PM
WhiteXKR's Avatar
Received 2,982 Likes on 2,123 Posts
xxx is the program code (Known as VCATS code). It usually can be found on a label on the left rim of the spare tire well, just under the side carpet.
If do not get a unit with the matching code, the dealer (or someone with access to the dealer tools) will need to program it.
  #72
Old 06-22-2012, 09:36 PM
Gus's Avatar
Gus
Gus is offline
I do not know if this will help with you specific repair Link JagRepair.com - Jaguar Repair Information Resource
  #73
Old 06-23-2012, 04:43 PM
XKR Brian's Avatar
I can fix your old module, that would be the simplest fix.
Email me if you like. Bambamm931@msn.com
kefroeschner (02-28-2015)
  #74
Old 11-16-2015, 04:17 PM
bevzorn's Avatar
Smile Seat Module Missing
Hello, I just bought my first Jag, and it is AWESOME!! However, the passenger seat module is missing. I called the Dealership, and this part has been discontinued. Any ideas where I can get part # LJE2160AB/XXX
I also understand that it has got to be programmed in order to work, so would need to get one with the coding erased so I can get it reprogrammed by the dealer.
Any help or ideas would be greatly appreciated
  #75
Old 11-16-2015, 07:26 PM
test point's Avatar
You are going to have to find an used one. The passenger seat module does not require programming as long as it is close enough to your part number. Pull the driver seat to see that.
  #76
Old 11-16-2015, 09:54 PM
bevzorn's Avatar
Default Seat Module Replacement
Thanks So Much! I will give that a try and let you know
  #77
Old 11-17-2015, 12:30 PM
XxSlowpokexX's Avatar
Hey Brian Im going to send you an email. Thanks
  #78
Old 11-09-2017, 04:56 PM
rflexible's Avatar
I have a 2003 XK8 with broken passenger seat module
  #79
Old 11-10-2017, 07:32 PM
Barry_Tucker's Avatar
If you need a module for the passenger side , I can confirm that a that LNC2160AD seat module is interchangeable with LJE2160AB. The only difference is that it has no memory function ( which the passenger seat does not have ) I just installed an LNC2160AD on my passenger's side and it works fine. The 160AD is much cheaper and easier to find on EBay
  #80
Old 11-10-2017, 08:06 PM
Is it PHYSICALLY BROKEN or ELECTRICALLY BROKEN??????? (or both??)
bob
File Type: pdf
Norri (11-11-2017)
Quick Reply: Seat control module
