Swap is Complete -- Lincoln LS Engine in My X-type Jag.
Old 03-07-2010, 02:39 AM
willy-k's Avatar
Default Swap is Complete -- Lincoln LS Engine in My X-type Jag.
First off - My 2002 Jaguar X-Type is a Original 2.5L car...Now has a 3.0L Lincoln LS Engine.......Runs Great ! Lots of Power! ..Low miles toooooo...Sweet!
The Swap:
2004 Lincoln LS 3.0L with 28K miles (super low miles)
Payed $100 for a complete block!! minus trans.
Keep your old engine until your completely done with the swap because you will need a few items from it.
Items Needed from old engine:
keep your old wire harness
Oil Pan
Oil Pick-up
the camshaft that controls the water pump
water pump
oil filter mount
a/c braket
Left Head Valve cover
fly wheel
Exhaust Manifolds
Harmonic Balancer
intake
fuel rail
front timing cover
Center Block water outlets/Inlets
thats about it.
Helpful info:
all four Camshafts on the Lincoln engine had same part #'s Stamped on it as my Jaguar engine.
Sensors( Crank, Cams ) are a Match in #'s
VVT the same
The Lincoln LS 3.0L is a total match with just a few parts thats different , just keep in mind that the Lincoln engine was not mounted sidewards as in the Jaguar.
Removal of old engine:
If you want to drop the whole frontend its totally up to you, but i think that is a hard way of doing things and risk getting seriously hurt as you have to jack the front way way up.
I went from the top, just moved wire harness to the side, removed trans bolts and torque converter bolts, front engine mount, exhaust and lift away! its tight so go SSSLLLOOWW..
Here is the pictures of the lincoln LS engine before the tear down:
Left Head Difference on the Water pump cam, the lincoln engine has its water pump on the front timing cover. ( you will need to swap your camshaft, or if you want a challenge & know how to get that pressed end shaft off you could just swap that )
Old & New
Same Part Number's
Front Timing VVT Lincoln engine ( total Match, everything is the same down to the count of teeth on the Chain )
Oil Pan Difference ( left pan is from the lincoln and NO its not dirty i used it for a drain pan earlier since im going to trash it anyway)
oil Pick-up's , you need to swap these.
after all the swapping of parts, the engine gets put in!( yes i removed everything on the front as i thought i was going to drop the frontend , BUT my GUT told me its easier & safety to go from the top)
I do have more pictures, that i will post later.. I also took some time to polish my valve covers......So sweet lookin
the total swap took me a few days, just take it slow. what did i gain? a sweet low miles 3.0L say good bye 2.5L !
Oh you do not need to replace your ECU..
anyone has Q's just PM me!
The following 5 users liked this post by willy-k:
Kasey penrod (07-27-2022), micki88 (06-17-2014), Panthro (09-11-2013), Patterson (05-04-2012), xplicitwhips (08-27-2012)
Old 03-07-2010, 09:08 AM
good job *****
Old 03-07-2010, 01:08 PM
looks good the,i know that the auto gearbox on the x type have 2 variants to withstand the extra torque,i would hold onto that ls pan might be able to sell it to a tranny shop they tend to snap the lower tabs off when replacing gearboxes. you can recoup some of your cost.
Old 03-07-2010, 11:13 PM
willy-k's Avatar
More Pictures:
Covers of shine!!!!
LS & Jag Intake
even this semi round things on the intakes are the same with matching part #'s.
anyone needs LS parts??
I have wire harness
Front cover
pulleys
water pump
fuel rail
exhaust
intake with throttle body
oil pan
valve covers
I was thinking about eb@ying everything i have left, maybe i could make my $100 back..
Panthro (04-11-2018)
Old 03-31-2010, 02:46 PM
vincek's Avatar
awesome job!
Old 03-31-2010, 06:50 PM
H20boy's Avatar
seriously, good project! thanks for sharing.
Old 03-31-2010, 08:10 PM
willy-k's Avatar
Thanks h20boy, hope it helps anyone out there wanting to do this swap, this was really easy if you have some time and the tools.
BTW the car runs great! Ive been driving it every day since the swap no problems at all..
my last thing i did on my car was taking a plastic razor and took that 2.5L logo off my trunk
Old 04-01-2010, 12:54 AM
Nice one *****, very informative.
Old 04-01-2010, 06:03 AM
Cadillac's Avatar
That's a mammoth job and you made it superbly ,well done
Old 04-25-2010, 04:47 PM
jonre's Avatar
wow! I would never had thought the Lincoln Engine would be the same. NICE JOB! 2 Thumbs Up for You !
Old 04-26-2010, 10:53 AM
ShadyJC's Avatar
Ok, seriously you need to buy this bumper sticker.
BillAdama (08-27-2012)
Old 04-27-2010, 11:18 AM
JEFFEE's Avatar
This by no means is an easy job. Don't try this at home folks.
Old 04-27-2010, 01:19 PM
steve11's Avatar
ud
The Swap:
Oil Pan
Oil Pick-up
water pump
oil filter mount
a/c braket
fly wheel
Exhaust Manifolds
Harmonic Balancer
intake
fuel rail
front timing cover
thats about it.
Helpful info:
VVT the same
Old & New
Same Part Number's
This is a brave project! My hat is off to you!
Old 06-15-2010, 10:07 PM
Reverend Sam's Avatar
Received 1,258 Likes on 564 Posts
Wow... looks like that took some work! What's the difference in horsepower between the 2.5 liter and the 3.0 liter?
Old 06-16-2010, 08:04 AM
tgds932001's Avatar
Default xj8 switch
Shouldn't that engine fit in a xj8 also. Has anyone ever replaced one.
Just wondering in case mine goes out.
Old 10-01-2010, 09:24 PM
armandjones82's Avatar
Having the lincoln ls parts to be swapped there is kinda interesting. I think that learning these kinds of steps would be very interesting to know and to learn. Hope that all is well after the swap.
Old 10-03-2010, 01:55 AM
myponyjose's Avatar
Nice!
Old 11-10-2010, 07:39 AM
Leedsman's Avatar
Congrats. ***** K, looks like a job well done -- and very satisfying as you drive along since you know it's by your own efforts. AND, the bigger the engine, the more cars seem to be fetching when sale time comes.
Cheers, Leedsman.
Quick Reply: Swap is Complete -- Lincoln LS Engine in My X-type Jag.
