replace brakes and rotors myself 2004 vdp
I change the brakes and rotors on my wifes van and on my own motorbikes, so would like to do them on the Jag.
Is there anything to look out for? Any potential "woops, shouldn'ta done that's?"
I'm at 60K (kilometers) Should I bleed them first? If not do I need to do anythng special re the ABS?
I'm just going to go with the OEMs. Any problems with that?
Any and all advice cheerfully accepted!
P.S. whats a good source of parts in Canada?
I actually just ordered brakes for my 04 XJ8 which would be the same brakes as your VDP. I just ordered them yesterday but I got them from www.perfectbrakes.com, I went with aftermarket pads and rotors which I think are a much higher quality then the OEM ones and they also happen to be cheaper. Besides having better stopping power from the research i've done one of the biggest things they have over the OEM ones is that they produce little to no brake dust which made a huge difference for me. I went with EBC Red Stuff pads and their XR series OEM rotors.
Here are the part numbers for them along with prices:
Product ID: 017008
Product Name: UPR1411 (12.6")
Quantity: 1
Unit Price: $124.87
Product ID: 037189
Product Name: UPR951 (11.3")
Quantity: 1
Unit Price: $76.04
Product ID: 009911
Product Name: DP31220/2C
Quantity: 1
Unit Price: $88.56
Product ID: 031689
Product Name: DP31221/2C
Quantity: 1
Unit Price: $88.56
Hope this helps,
Mat
Product ID: 017008
Quantity: 1
Unit Price: $124.87
Product ID: 037189
Quantity: 1
Unit Price: $76.04
Product ID: 009911
Quantity: 1
Unit Price: $88.56
Product ID: 031689
Quantity: 1
Unit Price: $88.56
Hope this helps,
Mat
Yes, just a couple of tips, and I give this info with reservation as I never know the technical competence of someone I've never met online, especially while working on such a critical function - the braking system. I don't mean to impugn your technical integrity, so please accept my apologies if that is the case. As in anything technically complex as the braking system, there are a hundred things that a comeptent tech will see and take appropriate action that a novice might miss and these things might fall out of the normal realm of the tpyical brake job.
DO NOT retract the rear pistons like you did on your wife's van as these pistions screw in. You need a special tool to accomplish that. If you try to push them in you'll permanently damage the rear calipers. You also have to make sure the parking brake is released. The front pistons do work like your wife's van and can be retracted probably the way that you did on the van.
This is a generic tip for all brake systems - I do not push brake fluid backwards through the system (especially ABS). Instead, I crack open the bleeder screws at each caliper right before I retract the pistons. Use a small piece of plastic tubing and let the brake fluid drain out into a container rather than pushing it back through the system.
I do flush the entire system and replace all the brake fluid if the car has more than two years on the existing fluid. Color is the best indicator. Brake fluid should be almost colorless, use new fluid color as the standard. If the fluid in the reservoir looks like the color of urine or dark honey then I flush the entire system using a power bleeder. This can also be done manually (two-person operation), but it takes some time.
On pads, I always replace OEM pads with ceramics. I'm not recommending any special brand as there are mumerous choices. You'll be much happier with their performance, cleanliness, etc. And, the prices of ceramics are in a range that is not cost prohibitive.
Best of luck to you
Best of luck to you
Just a Thought on OEM
I don't have any specific advice for you on the 04, as I haven't had my X350 long enough to do anything to it. But when you said you were planning on just using stock OEM parts, I thought I'd suggest you consider otherwise.
I bought my 2000 XJ8 new, and the stock brakes were completely shot before 20,000 miles. I wasn't pleased. I went to the local discount auto parts store and bought whatever normal brand of pads they sold with lifetime warranty on them and put them on myself. I got 90,000 miles on those pads before I had to replace them again (for free, of course). I never noticed any significant difference in performance from the stock pads. Good luck,
Goose
Goose
Thanx for the tip!
Goose
All info happily accepted - thanks!
This is what I had read somewhere, and wanted verification on. Thanks!
Again, good info. Corroborates what I had read, but here it comes from the "horse's mouth" so to speak! [Thumbup]
Best of luck to you
Best of luck to you
fluid
Good on the bleed when pushing back pistons Stevetech. I've been doing this for years and am suprised at how many post I've seen on brake repair that don't mention this.
Don't want any of the old crap pushed back into the system. I've been using Superblue brake fluid which is blue in color so you can easily tell when the flush is complete.
Chad
Chad
I bought the tools for the rotary rear caliper piston retraction from Harbor Freight, for about $35. They worked fine. I also use a plastic clamp that looks like a locking scissors to clamp the brake line to keep crud from going back into the system. I usually replace all the brake fluid after a brake job, I use a pressure bleeder (Motive Power) which makes it a fast one-man job.... run it at about 15 psi. If the car is over about 5-6 years old, I also replace the brake hoses in this operation. Cheap parts and you're right there.
BrentGardner
26
Yesterday 05:19 PM
philwarner
12-06-2021 07:13 AM
Doberman_Fan
22
12-24-2019 06:21 AM
