'04 XJR drivers side heat problem
Old 09-30-2009, 12:45 PM
Replace the heater control valve in the passenger front lower engine compartment and hope that it was only stuck closed and didnt short the ac control panel
Old 10-09-2009, 11:06 AM
Uh yes i work on them all day, it has a heater control valve(dual) that how it allows 2 different temp setting between the passenger and driver
Old 02-27-2016, 01:44 PM
Grant hill's Avatar
Wondering if anyone can help me... Have a problem with the climate control on th drivers side... Passengers side working fine and drivers side has nothing.... This car is a 2004 Jaguar XJ the pipes are warm going into the car but is only heating passengers side also the vent controls are working can someone help please
Old 02-27-2016, 01:55 PM
Fraser Mitchell's Avatar
Received 2,430 Likes on 1,940 Posts
This is a well known syndrome and usually caused by the heater matrix being partially blocked. Unfortunately, this is a fairly major job to fix, so expensive in labour charges. You could, as a first step, try flushing the matrix, but success is by no means guaranteed. It is not necessary to dismantle the whole console, but there is still a lot to do.
These cars also have an auxiliary coolant flow pump to assist the circulation through the heater, but if this has failed, you'd likely have little heat on either side of the car. It's worth checking this pump, though, just in case it has failed. The pump pulls coolant through the heater rather than pushing it.
Old 02-27-2016, 05:28 PM
Sochi2014's Avatar
Don't bother with heater. You have to change that aux pump. It will solve issue 105%. Did on my car.
Old 12-06-2016, 06:25 PM
KJ4YXY's Avatar
I replaced the aux pump and it did not work for me...
Old 12-07-2016, 02:39 AM
meirion1's Avatar
As Fraser said it's the matrix.
I have never had to do it myself but I have dropped the glove box which is what you
need to do to access the matrix.
The only bit that would bother me is the pathetic clips that attach the two hoses to the matrix.
Old 12-07-2016, 05:07 PM
Lagonia's Avatar
You do get power to the pump and the pump is pumping, correct? That was my solution to this problem.
xjrjag
10-27-2021 11:48 PM
jdzubas
10-04-2015 09:14 AM
Aranon
09-03-2015 07:56 PM
johanasu
09-03-2015 12:39 PM
frankc
09-01-2015 04:41 AM
Quick Reply: '04 XJR drivers side heat problem
