Brake light relay...
Old 09-28-2009, 09:15 PM
Bowmanconsult's Avatar
Default Brake light relay...
Gang,
I bought my 1999 XK8 several weeks ago and have been having rear light issues from day-1.
Here's my question...does the brake light relay take a different relay than the other relays in the board?
The one that is in the brake light slot now is LJA6703AA.
Here's what prompts me to ask;
I removed several adjacent relays and took my volt meter to them and easily found the hot plug, the ground plug, etc.
But all 4 posts on the brake light relay had voltage running to it, and the voltage left one of the posts when the brake pedal was depressed. The exact opposite of what I would expect.
Hmmmm!
My assumptions would be;
-This relay slot uses a different style of relay than the other slots
or
-I have a short in the wiring somewhere before the relay slot.
If this slot demands a different relay, then I would be one happy boy, so any help here would be greatly appreciated.
Old 09-29-2009, 06:09 AM
test point's Avatar
The electrical schematic shows the stop light relay to be the same as the related (tail, backup) relays.
There is a history of ground problems in the tail light assembly.
H20boy
07-23-2021 09:39 PM
mbergen
10-23-2019 10:26 PM
jdzubas
10-04-2015 09:14 AM
KarimPA
09-12-2015 08:15 AM
motorhead69
09-09-2015 10:04 AM
Quick Reply: Brake light relay...
