Low Side AC Port Location on a 2000 3.0 S-Type
Old 07-08-2009, 01:06 PM
MHrusovsky's Avatar
Default Low Side AC Port Location on a 2000 3.0 S-Type
Quick Question!!
I've been searching the forums and I've found conflicting info on where I would be able to find the low side service port for the AC on a 2000 S-Type 3.0 L engine. Some say it's located on the compressor, others say its in the right rear corner of the engine compartment, and others say it's under the car on the hose...
I was wondering if it's easily found or do I have to get the car up on a lift?
Thanks!
-Mark
Old 07-08-2009, 04:54 PM
MHrusovsky's Avatar
OK, I found on the forums where it states to find the low-side AC Port, which on this model is located on the compressor, behind the driver's side wheel.
Yet, I noticed I'm having a hard time connecting the quick release tube to the low side port. Seems like it doesn't want to connect, i.e. not able to slide down enough for the quick release to catch... Also, I noticed a bit of oil in the area. I'm wondering if the 'over the counter' recharge cans you can buy, might not fit.
Has anyone had any success with recharging their own ac? Or, is this something that I might have ot take into the shop for?
Bcrary3
09-12-2021 05:41 AM
cissdm
05-03-2016 06:02 AM
afterburner1
12-16-2015 12:12 AM
tberg
09-07-2015 07:32 AM
pocketrocket
09-03-2015 07:44 PM
Quick Reply: Low Side AC Port Location on a 2000 3.0 S-Type
