2000 S-Type Stalling During Ilde
Old 04-30-2007, 09:08 PM
Envy337's Avatar
Default RE: 2000 S-Type Stalling During Ilde
Can you head a "hissing" sound at idle (and giving it gas) with the hood up?
Old 05-01-2007, 12:11 AM
Envy337's Avatar
You might have a major vaccum leak (hence the hissing) causing the car to stall. There are 2 breather rubber elbows that go bad and cause that. What codes did you have before?
Old 05-01-2007, 02:15 PM
bigdreams05's Avatar
Will the car start right-up after it shuts off, or does it hesitate, or does it need a jump after it starts up?
Old 05-01-2007, 11:11 PM
Envy337's Avatar
Did the service center scan for codes?
You did have lean codes. Lower intake gaskets????? I've never seen them replace due to leaking. Was this a Jag dealer?
Can you get part numbers for the parts they replaced, this doesnt sound right.
Old 05-03-2007, 01:06 PM
badmojo's Avatar
I have an 03 S-type r and would like to replace the fuel filter but I'm not sure where it's located?
Old 05-03-2007, 05:06 PM
How did you release the pressure in the fuel lines?
Old 10-10-2007, 06:01 PM
Hey fellas (if u r still around). I am having the same issue. Where exactly can I find the elbows? If I need to replace them, where can I find the replacements?
I have a 2001 S-Type 3.0 88k miles
Old 10-12-2007, 10:27 AM
Thanks...so does it make more sense to replace the fuel filter first? I am also getting some hesitation at normal speeds today.
Quick Reply: 2000 S-Type Stalling During Ilde
