How many foot pounds to torque down wheels?
Old 04-01-2009, 09:34 AM
ocduff's Avatar
Default How many foot pounds to torque down wheels?
Anyone know the factory recommended torque specs for tightening wheels on? I plan on rotating my tires soon. I have the factory comprehensive manual on CD-ROM, but it takes about an hour to find an answer to even the simplest question. Hence making it pretty useless.
Is there a site that has this kind of generic information? I need to know what the torque specs are for my Honda too.
Thanks in advance.
Old 04-01-2009, 08:33 PM
Doug's Avatar
I torque mine to 65 ft lbs. Not sure what the spec is, but that's what I use.
Someone will come along with the correct spec.
DD
Old 04-01-2009, 11:01 PM
dougs02's Avatar
According to my owner's manuals 65-75 Ft. Lbs.
Doug
Old 04-02-2009, 08:08 PM
ocduff's Avatar
Thanks Doug's.
Old 04-24-2009, 12:56 AM
panchostatus's Avatar
100 ft lbs is what we do in the shop. so its a little difficult to get off with a tire iron, your wheels won't fly off when you take that corner at sixty
Old 05-14-2009, 07:58 AM
Mac.XJS.Florida's Avatar
65-75 is correct. I use 70. I have heard that too tight can cause the brake rotor to warp. I suppose that on some cars this is true, while others it may not be much of a concern. I know I could tighten the lugs on my 69 Lincoln till just before the stud snapped and it would not affect the rotors. I avoid re-engineering the car. Some guy spent a lot of time in college getting his degree, then spent a lot of time testing what worked best. Sure that guy could have made a mistake, or had to compromise for cost or EPA concerns, but for something like this? 65-75 works for me.
mrplow58
01-21-2024 05:53 AM
aholbro1
08-05-2021 05:02 AM
fingers
09-11-2015 12:21 PM
iownme
09-11-2015 02:57 AM
fingers
09-08-2015 03:54 PM
Quick Reply: How many foot pounds to torque down wheels?
