Code P1796, Help
Old 02-25-2007, 11:53 PM
smokinjag's Avatar
Default Code P1796, Help
I hooked up the OBII scanner up to the Jag because the check engine light came on and got the code P1796, which indicates a kick down switch circuit malfunction, can anyone tell me what needs to be done to correct this problem?
Old 02-25-2007, 11:55 PM
Default RE: Code P1796, Help
Nope soz.
Racer or Buck will probably have an idea.......no doubt they'll be along soon.
JC
Old 02-26-2007, 12:27 PM
bigdreams05's Avatar
It makes perfect sense. Thank you!
Old 02-26-2007, 02:14 PM
smokinjag's Avatar
I guess my next question is how do i fix it?
Old 02-26-2007, 08:37 PM
racerx82's Avatar
P1796 Vehicle Speed Signal Short To Ground
Sounds like one of the wheel or trans output sensors is bad.
Old 02-26-2007, 09:06 PM
racerx82's Avatar
My bad, you must have an 04 or 05 X type with that code....
Book say's it's a CAN network fault.
Wire in CAN network malfunction.
Sounds like a bad wire from the trans to ECM....I can't get any more info....sorry
Old 02-27-2007, 11:35 AM
smokinjag's Avatar
I actually have an 02'
Old 02-28-2007, 11:04 AM
smokinjag's Avatar
bump.
Old 08-17-2014, 10:16 PM
bgshaw's Avatar
Default Code 1796
Hello from Calgary Canada
I have just bought a 2004 x type Jaguar 2.5 L automatic and in the two hours I have driven it my check engine light went on. I have no ability to kick down at high speed and I have a code P 1796 and P0 333. i tried to reset codes but my cheap Autel code reader would not clear the codes. When I tried to reset the codes. The transmission failsafe came on and I just had 4th gear. When I removed code reader and let sit then re started car the car was not in failsafe mode and shifted fine check engine light was still on however.
Transmission failsafe only came on again when I tried to reset codes with reader. I did notice the following when I drove the car after I started the car again back to normal with Check engine light up shifting no problem but no kick down for fast acceleration. down shifting was a littler erratic however.
i have a 2004 but It was and early on so I am wondering if it is kick down switch as I have this symptom.
Any help is appreciated
Barry
Calgary
philwarner
25
06-26-2021 05:43 AM
bdboyle
09-16-2019 05:58 PM
JCam
10-23-2016 08:27 PM
tsimms7
09-15-2015 12:43 PM
philwarner
09-02-2015 11:45 AM
Quick Reply: Code P1796, Help
