Heater Core pics for 1997 XJ6?
Old 02-12-2014, 07:55 AM
jakeperigo's Avatar
Default Heater Core pics for 1997 XJ6?
I was reading about the heater problems and heater core issues with the XJ6? Does anybody have any pics of the heater core to flush? I only saw 2 post on heater cores in the X300 section. I can flush it this weekend but i would like some experienced people to give me some advise. So that it goes smooth....
Thanks so much
jake
Old 02-12-2014, 08:15 AM
aholbro1's Avatar
Received 1,638 Likes on 1,066 Posts
Old 02-12-2014, 08:33 AM
AllanG's Avatar
Follow the hoses that come out of the heater solenoid valve and the heater coolant pump. You will see two hoses that connect to two metal tubes that go through the firewall. To back flush the matrix, disconnect the two hoses and hook up a garden hose to the one that goes to the heater valve and a discharge hose to the other. Increase flow slowly, if no flow the core is blocked and not much you can do except remove it which is a pain
jakeperigo (02-13-2014)
Old 02-12-2014, 02:14 PM
b1mcp's Avatar
As Allan described. Note this is RHD.
Old 02-12-2014, 02:30 PM
b1mcp's Avatar
This is the actual matrix where those two pipes end up.
Old 02-13-2014, 02:20 AM
sparkenzap's Avatar
And there is almost tha much dissambly required on a LHD car to get to it!
Actually, you "only" need to lower the steering column, remove some modules and the brake pedal assembly, as I recall. The manuals were not modified for the LHD car, so none of that was in there!
Old 02-13-2014, 07:31 AM
jakeperigo's Avatar
Thanks guys.... will get it done today....
Old 02-13-2014, 07:33 AM
jakeperigo's Avatar
Thanks guys... will do it today.. with the great weather here in Texas
02jagstype
23
10-23-2022 07:03 PM
Kevin Burnaby
06-28-2020 08:04 AM
rusty37
04-05-2020 07:40 PM
texaspete
09-10-2015 08:34 AM
Steve10
09-09-2015 07:54 PM
Quick Reply: Heater Core pics for 1997 XJ6?
