How to headlight repair stype FAQ
Old 01-28-2009, 08:40 PM
Brutal's Avatar
Default How to headlight repair stype FAQ
for those of you with broken headlights, heres the fast and good fix that works. If your headlights are broken and point down like grandma's t...well you know. Take 2 screws and install through clear lense behind rubber. See pic, the idea is to pin the assembly back to take place of the pin that broke inside. A screw about and 1" long works best if only the top post is broke, if totally broke top and bottom as the 1's I fixed in the pics, youll need longer..about an 1 1/2". Some have a chrome piece you screw into till it touches, these had a white piece with recessed hole that the screw went into and held. If you dont get the idea from this and the pics...well maybe you shouldnt try, but its better than buying new...
The following 29 users liked this post by Brutal:
aholbro1 (10-15-2011), airanp (07-13-2012), Amadauss (10-05-2011), amoeba (09-22-2012), Bacardi 151 (01-08-2012), Deacon (03-05-2011), DougB (10-22-2012), ffhillclimber (04-09-2011), Gearhead351 (03-25-2016), Glyn E (08-16-2012), Greg P. (02-12-2011), hafferf (03-01-2013), jeffn (04-18-2016), Jumpin' Jag Flash (04-22-2013), knockdhu (01-28-2011), maddyn (06-24-2011), oPiranha (01-29-2014), Panthro (09-25-2018), pastype (02-10-2012), Ragn0r (01-12-2016), saltyraoul (05-09-2016), Sarahtonin (01-01-2018), scubadeb (04-04-2012), Shadow Bear (07-30-2011), stanjag (11-13-2012), STR-Snowbird (01-22-2013), the beagle (12-04-2011), tmurray (06-26-2012), Vampyre (06-24-2011) and 24 others liked this post. (Show less...)
Old 01-28-2009, 08:47 PM
Default RE: HOW TO HEADLIGHT REPAIR STYPE
You ain't no photographer. but the main thing is you pointed out the fact that they can be easily repaired. Great tip for alot of people, thanks.
Old 01-28-2009, 08:49 PM
mep's Avatar
mep
mep is offline
Thanks for the tip and pics!
Old 01-28-2009, 09:04 PM
Brutal's Avatar
ORIGINAL: JagtechOhio
thats not my claim to fame, but I tried to delete the blurry pics,,,nope. but gives you the idea....i do try to help not only people here but customers at work too... that was a free fix for that guy so I could take pics....he was VERY gratefull
Old 01-29-2009, 10:07 AM
NvmyJag's Avatar
Just went to the car and pushed on the high beam connector and now everything makes sense and all my questions are answered except one. Will they still come up when you turn the car on?
Michael
Old 01-29-2009, 10:40 AM
NvmyJag's Avatar
Headlights are fixed thanks to Brutal and his detailed explanation, now to wait until tonight for the real test. I'm still looking for a LOW PRICE OEM parts person because you never know what's going to break next.
Old 01-29-2009, 12:07 PM
Size:  6.3 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Size:  9.9 KBName:  tshirt03-2.jpg
Nice one Brutal......good write up although the pics are terrible....lol
I'm gonna have to send you on that 2 week photography course to the Carribean as we discussed......all expenses paid of course
I'm gonna FAQ this for the benefit of future members who will no doubt ask this question
Jim
Old 01-29-2009, 12:42 PM
You make it look so simple. It makes me question the intelligence of the two techs who both told me I need to spend $3K to get them fixed.
Bless you.
Old 01-29-2009, 01:43 PM
Brutal's Avatar
Default Re: How to headlight repair stype
ORIGINAL: hottienamedscottie
Bless you.
Until I told everyone here no one new how to do it, and Im still the only1 here to heat headlight assemblies in the oven at 250 for 10 mintues to soften the urethane and easily take them apart for repair. I believe in keeping not only Jaguars but all cars I own up to like new condition(although everything I own is pretty heavily modifyed). This follows what I believe in work too, I cringe when people just let a Jaguar fall apart from neglect....somethings like this and others help to keep the whole ownership time a relatively happy 1. I would not spend 3k on headlights, blower yeah, but everyone has their own financial thresholds and theyre all different for different people
The following 3 users liked this post by Brutal:
Greg P. (02-12-2011), stanjag (11-13-2012), Trisha Gamble (09-17-2017)
Old 03-12-2009, 09:03 AM
Brutal's Avatar
Well i cant see your pics at work, but yes you go to the side of the piece, i never drill i just use my makita cordless driver and screw right in. Have you verified that it is broken inside?
Old 03-12-2009, 01:10 PM
NvmyJag's Avatar
Default Mine were just like yours
OK, so brass tacks time. What the heck do I do with this? Use a fairly small diameter drill bit at an angle?
1. You can use a small drill bit or just drill a sheet metal screw into the clear plastic. I used a small drill bit and then went in w/the screw.
Find some way to remove that protruding piece of plastic with the vertical hole in it?
2. You don't need to touch the plastic piece w/the vertical hole in it.
The best way to explain it is that you have to put a screw into the plastic and that screw will push against the chrome piece inside which will bring the head lights up.
Old 03-12-2009, 03:45 PM
dwhitall's Avatar
I would also add, don't use a self tapping screw as it will go through the chrome backing. Using a powerdriver you can get a screw to go through the headlight, but it might be easier to start the hole with a drill.
One final note, I got this to work in that it made the headlight useful again (pointing at the road, instead of a spot 5 feet in front of the car), but it did not fix it to the point that it could be aimed within state inspection standards. So I still had to replace the headlight assembly
Old 03-12-2009, 05:26 PM
Brutal's Avatar
What did you do, go to a inspection station where they roll out a level testor????? Gotta love big brother
Old 03-12-2009, 05:43 PM
Sayno's Avatar
My headlights seem to point low 98% of the time, but one time when I started the car the headlights leveled almost TOO high. Is this still a problem that can be fixed with the screw?
Old 03-12-2009, 06:58 PM
Brutal's Avatar
take the radiator cover off to expose the back of the headlights, grab the connector for the hi beams and wiggle, if it flops around its broken, then yes it will work
Gearhead351 (03-25-2016), jeffn (05-02-2016), stanjag (11-13-2012)
Old 03-12-2009, 10:41 PM
Sayno's Avatar
Well I took the cover off and I could move the headlights freely. . . heh
Ran down to home depot got a nice 12v Li-Ion drill and 4 sheet metal screws. Came home and went to work.
WOW! What a difference. I'll get some pics tomorrow in the sunlight, I had the chrome piece so it should compliment Brutal's pics nicely
Old 03-13-2009, 06:56 AM
Brutal's Avatar
glad to help you out, this is why I like to do this kinda stuff.Yes there are times and people that only want it back to exact function and original. And those that FIX everything, and then the mixture of both. I always belive in save where you can, spend where you want
The following 2 users liked this post by Brutal:
Ace Ford (09-27-2016), motofreak72 (12-06-2014)
Old 03-13-2009, 07:13 AM
Jon89's Avatar
Received 4,276 Likes on 2,813 Posts
After reading through this thread I sure am glad that our S-Type doesn't have the self-leveling headlights option. It sounds as if Jaguar really under-engineered this one....
Quick Reply: How to headlight repair stype FAQ
