Jaguar Technician Information System (JTIS) download
#101
Hi
I'm getting an error message (Another application is currently using DAO files. Close all other application. Continue?) when trying to install the dao35 as is asked in the setup file and I'm not running any other programs. Anyone has any suggestions on how to fix it or go around it.
thanks
thanks
i have the same problem, has anybody a solution?
thanks.
#102
I don't believe it will install on Vista or Windows 7. It needs XP to function properly. Maybe XP Mode on Win7?
I found a new link for the files:
http://www.mediafire.com/?sharekey=0...6b94653a3044fd
IXLLER8 (06-26-2017)
#103
#104
The JTIS is supposedly for use by experienced mechanics (ie Jag mechanics at dealers)
For full info go to Jags GTR site subscribe (£8 for a days subscription when I subscribed) and download /view detailed info.Dont subscribe on a Sunday as the site often goes down then for updates as I found out but did get 5 days free when I conplained
#107
Guest
Posts: n/a
used JTIS successfully for timing chain tensioners & bent EXH valves
I used JTIS successfully to go all the way into an AJ-V8 in a 2000 S Type to replace timing chain tensioners, chains, remove cylinder head to have 4 bent exhaust valves replaced. After selecting your make and model in the start screen use the display index button on the bottom left and navigate to "in vehicle repair" to timing chain section 12.65.67.
Disassembly and assembly procedure chapters are directly below. I ran it on my laptop under XP with the free dao35 update download from MS support page.
The pictures were good and you can also print them if needed. It is like having a freind working along with you. Definitely helped with timing and getting the PS pump and AC compressor re-installed easily.
Cheers! It runs!
Cheers! It runs!
#108
Guest
Posts: n/a
No good................
JTIS DOES NOT WORK .... I HAVE TRIED EVERYTHING ,A WAST OF MONEY...
If you buy a cd repair manual, you should not have to buy another cd to
tell you how to use that repair cd. Just my thought on the subject.Could
you picture buying a stack of cd but could not use any of them .That is
what this is like/////////////////////////////////
#109
#110
#113
Jaguar Manuals
http://www.ownerinfo.jaguar.com/extf...prod/index.jsp
There appear to be 4 different manuals available for your model.
It breaks each of them up into seperate pieces, so you have to download all pieces of each of them seperately, but at least they are there, for now. I would suggest downloading now while you still can. They keep moving them deeper and deeper into their website, and I assume they will eventually be unavailable directly from Jaguar without a fee.
PS: The link is maintained by Jaguar themselves, so it's completely legal. You can access it from their main site, but I've given the direct link.
#116
Thanks again Christo - just downloading at the mo!
Just to let you guys now, have been getting tapping noise from the RH (?? the one closest to the driver!) bank, which gets worse on acceleration, but seems to drop off when take foot off throttle - inital thoughts were timing chain - replaced that (t was as loose as a tarts proverbial!), put engine back in car, and all seemed good....until engine warmed up again and the tapping noise came back.... BuckMR2's post here http://jagmotorproject.blogspot.com/...verything.html has been really useful in doing this work - now thinking that it might be the shims, the valves, or the valve springs, so am going to start from the top and work down checking it all.....sigh... will try and put some postings up as I'm doing the work, together with some pics, if I can work that bit out!! (bit of a newbie to this forum!)
Any other suggestions or help would be greatly received!!
#117
#118
It will only run on Windows XP, not Vista or Windows 7. Not sure if that's what you are using, but just a thought. You can run it in an XP Virtual Machine just fine.
#119
If you had any probs which I didnt on Vista run the program as if it was running on XP from Vista
#120
